POV-Ray : Newsgroups : povray.general : Photons scattering and saturation Server Time
22 Feb 2025 18:34:22 EST (-0500)
  Photons scattering and saturation (Message 1 to 3 of 3)
Subject: Photons scattering and saturation
Date: 30 Dec 2011 05:45:00
Message: <web.4efd956b3dba9ea2ffd83c460@news.povray.org>
Hi all,
I'm a newbie.. I've two problems with this file:
1) there is no media scattering on the central beam (that collimated by the
reflector) while there is scattering on the direct radiation. How to obtain
light scattering from the central beam?
2) The central beam is not uniform, but it appears so: the spot is saturated.
How to avoid this? How to have a more gradual representation of the
illumination? (note: this happens always, also even when the media scattering is
not present).
Thanks anybody!
global_settings
{ photons
  { count 5000
   media 100   //  This parameter has no influence !?
#if (1)
        camera { location <-60,30,-150> look_at <50,-20,0> angle 60} // lateral
prospective view
#else
        camera {orthographic location <5,0,0> look_at <50,0,0>}   // frontal
orthographic view
// screen
#declare xpos = 60;
box {
     <xpos, -60, -60>, <xpos+10, 60, 60>
        pigment {rgb <1,1,1>}
        finish {ambient 0.1 reflection 0 diffuse 1}
        photons {target}
#declare lampandreflectorxpos = -20;
// lamp
light_source
{ <lampandreflectorxpos, 0, 0>,
  color rgb<1, 1, 1> * .1
  //area_light z,y,4,4
  photons { refraction off reflection on }
#if (0) // stop for the direct radiation, placed in front of the lamp
cylinder
{<lampandreflectorxpos+1,0,0>,<lampandreflectorxpos+1.5,0,0>,1.5}
#if (1) // smoke block for scattering
cylinder { <lampandreflectorxpos-3, 0, 0>, <xpos+1, 0, 0>, 60
  pigment { rgbt 1 }
  interior {media {scattering { 1, rgb .05 extinction 0}}}
  hollow
// Reflector
// Internal specular surface
lathe {quadratic_spline 61,
<15.0506,26.2944>
<14.9282,25.8564>
<13.7045,21.4767>
<12.6537,18.0146>
<11.7408,15.2308>
<10.9395,12.9592>
<10.23,11.0815>
<9.5966,9.5118>
<9.0272,8.1864>
<8.5122,7.0572>
<8.0436,6.0874>
<7.615,5.2486>
<7.2212,4.5183>
<6.8577,3.8786>
<6.5209,3.3153>
<6.2076,2.8168>
<5.9151,2.3736>
<5.6413,1.978>
<5.384,1.6234>
<5.1417,1.3046>
<4.9128,1.0169>
<4.696,0.7566>
<4.4903,0.52035>
<4.2946,0.30541>
<4.1079,0.10939>
<3.9296,-0.069755>
<3.7589,-0.23381>
<3.5952,-0.38432>
<3.4379,-0.52263>
<3.2864,-0.64992>
<3.1404,-0.76722>
<2.9994,-0.87545>
<2.863,-0.9754>
<2.7309,-1.0678>
<2.6027,-1.1533>
<2.4781,-1.2324>
<2.357,-1.3056>
<2.2389,-1.3734>
<2.1238,-1.4362>
<2.0113,-1.4943>
<1.9014,-1.5481>
<1.7937,-1.5978>
<1.6881,-1.6438>
<1.5845,-1.6862>
<1.4827,-1.7252>
<1.3826,-1.761>
<1.284,-1.7939>
<1.1868,-1.8239>
<1.0908,-1.8513>
<0.99606,-1.876>
<0.90231,-1.8982>
<0.8095,-1.9181>
<0.71751,-1.9356>
<0.62626,-1.951>
<0.53564,-1.9641>
<0.44556,-1.9752>
<0.35592,-1.9842>
<0.26663,-1.9911>
<0.17761,-1.9961>
<0.08876,-1.999>
<0,-2>
  photons { target reflection on collect off }
  finish { reflection 1 ambient 0 diffuse 0 }
  rotate -90*z
  translate <lampandreflectorxpos,0,0>
// External case
<15.0506,26.2944>
<14.9282,25.8564>
<13.7045,21.4767>
<12.6537,18.0146>
<11.7408,15.2308>
<10.9395,12.9592>
<10.23,11.0815>
<9.5966,9.5118>
<9.0272,8.1864>
<8.5122,7.0572>
<8.0436,6.0874>
<7.615,5.2486>
<7.2212,4.5183>
<6.8577,3.8786>
<6.5209,3.3153>
<6.2076,2.8168>
<5.9151,2.3736>
<5.6413,1.978>
<5.384,1.6234>
<5.1417,1.3046>
<4.9128,1.0169>
<4.696,0.7566>
<4.4903,0.52035>
<4.2946,0.30541>
<4.1079,0.10939>
<3.9296,-0.069755>
<3.7589,-0.23381>
<3.5952,-0.38432>
<3.4379,-0.52263>
<3.2864,-0.64992>
<3.1404,-0.76722>
<2.9994,-0.87545>
<2.863,-0.9754>
<2.7309,-1.0678>
<2.6027,-1.1533>
<2.4781,-1.2324>
<2.357,-1.3056>
<2.2389,-1.3734>
<2.1238,-1.4362>
<2.0113,-1.4943>
<1.9014,-1.5481>
<1.7937,-1.5978>
<1.6881,-1.6438>
<1.5845,-1.6862>
<1.4827,-1.7252>
<1.3826,-1.761>
<1.284,-1.7939>
<1.1868,-1.8239>
<1.0908,-1.8513>
<0.99606,-1.876>
<0.90231,-1.8982>
<0.8095,-1.9181>
<0.71751,-1.9356>
<0.62626,-1.951>
<0.53564,-1.9641>
<0.44556,-1.9752>
<0.35592,-1.9842>
<0.26663,-1.9911>
<0.17761,-1.9961>
<0.08876,-1.999>
<0,-2>
  pigment {rgb .5}
  finish { reflection 0 ambient .8 phong 0.5 }
  rotate -90*z
  scale 1.05
Subject: Re: Photons scattering and saturation
Date: 30 Dec 2011 06:15:00
Message: <web.4efd9cbc1a64677affd83c460@news.povray.org>
I've just found the solution to the first problem (after 3 days without
results!!): the reflector and its shell must be declared hollow. Without the
"hollow" parameter, the media does not work well.
I'm really a newbie :)
IGM
Date: 30 Dec 2011 20:57:09
Message: <4efe6bf5@news.povray.org>
> Hi all,
> not present).
> Thanks anybody!
> global_settings
> { photons
>    { count 5000
That's a very small value. You should use AT LEAST 10 times that amount,
more probably even something like 100 to 1000 times more.
I prefer to use spacing. Try replacing your count by spacing 0.3.
It allow your media to receive photons. Without it, no photons effect
will be visible in your media.
> #if (1)
>          camera { location<-60,30,-150>  look_at<50,-20,0>  angle 60} // lateral
> prospective view
> #else
>          camera {orthographic location<5,0,0>  look_at<50,0,0>}   // frontal
> orthographic view
> #end
> // screen
> #declare xpos = 60;
> box {
>       <xpos, -60, -60>,<xpos+10, 60, 60>
>          pigment {rgb<1,1,1>}
>          photons {target}
NOT needed. This object collect the protons, it never reflect nor
refract them.
> // lamp
> light_source
> {<lampandreflectorxpos, 0, 0>,
This is a realy bad area_light array. You should reasonably don't go
under 9,9 and use adaptive. circular orient is also very usefull.
Not needed as it is, use photons{area_light} if you plan on using an
area_light.
> cylinder
> #end
> cylinder {<lampandreflectorxpos-3, 0, 0>,<xpos+1, 0, 0>, 60
>    pigment { rgbt 1 }
>    hollow
Here, adding photons{passthrough} can prove usefull whenever the
light_source is outside the container and your target is in or beyong it.
Not absolutely needed here as the light is inside the container. It's
good idea to take the habit of adding that just in case.
> #end
