POV-Ray : Newsgroups : povray.general : rendering partially wet material Server Time
4 Mar 2026 22:32:34 EST (-0500)
  rendering partially wet material (Message 1 to 10 of 16)
Subject: rendering partially wet material
Date: 7 Aug 2011 04:25:01
Message: <web.4e3e4b7c7da1560a4c0a951f0@news.povray.org>
Dear POV-Ray users,
is there any person who has an experience to render some kinds of wet materials
such as cloth, sponge, etc? I read a SIGGRAPH paper:
http://graphics.cs.kuleuven.be/publications/PFPBFS/PorousFlow.pdf
This paper says that they used POV-Ray for rendering, but not so much in detail.
How can I use POV-Ray to render these kinds of materials? Would you please give
me some idea or tip? :)
Subject: Re: rendering partially wet material
Date: 7 Aug 2011 11:17:05
Message: <4e3eac71@news.povray.org>
The paper seems to be mostly about simulating the behavior of the
fluid, so I think they get some complex water geometry out which they
can then render as water in addition to the object (also the object
mesh is probably deformed by their algorithm as it soaks).
It may be quite difficult to get decent results. Some things you
can do is make those parts of the object that are wet darker and
with more reflection, and add some water geometry such as droplets
with trace function.
Date: 7 Aug 2011 13:10:24
Message: <4e3ec700$1@news.povray.org>
>> in detail.
>> please give
It's a particle-based simulation. You should look for particle in the
object collection for a good start point.
Date: 7 Aug 2011 22:05:00
Message: <web.4e3f4397a119247b4c0a951f0@news.povray.org>
The simulation is not matter for me, because it's my major research area. I'm
quite familiar to computational fluid dynamics and fluid simulation in computer
graphics field.
I'm wondering how I can make POV-Ray to recognize such partially darker and more
reflective regions. Using texture? (manually generated one using saturation or
density data coming from the simulation result) media? or other way?
Kiwon Um
Date: 8 Aug 2011 13:39:00
Message: <4e401f34$1@news.povray.org>
> graphics field.
> Kiwon Um
You can use layered textures.
You start with your base texture.
You place another, mostly transparent, texture over it. Dry areas are
totaly transparent, with a non-reflective finish. If you have specular
or phong highlights, make those broad and low intensity.
Wet areas use a filtering pigment and a finish having some variable
reflection: reflection{0.1, 1 fresnel}. Add conserve_energy to the
finish. This part should have moderate to strong specular or phong
highlights that are relatively tight.
Add interior{ior 1.33} to your object as it's wet with water. You need
an ior for the fresnel computation.
If it's suposed to be "wet" from some other kind of liquid, use the ior
for that liquid. The minimum reflection could also be adjusted as needed.
Date: 9 Aug 2011 02:35:20
Message: <4e40d528$1@news.povray.org>
Le 08/08/2011 19:39, Alain a écrit :
>>>> much in detail.
>>>> please give
>> area. I'm
>> computer
>> graphics field.
>> darker and more
>> saturation or
>> Kiwon Um
> Alain
I would cheat further: using the object pattern, assuming you have the
collection of wet spots (as particle, they might be promoted to sphere)
in a union, it's a simple matter of providing a wet and a dry look for
each object.
Real liquid part must be coded as usual, but it is only them which need
an actual ior. The other solids can remain as previously, just changing
the wet/dry look based on the object pattern and its inside tests.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 9 Aug 2011 12:20:01
Message: <web.4e415d22a119247b4c0a951f0@news.povray.org>
> each object.
This is a brilliant idea. Then, there is a question. Does the *object pattern*
support for smooth edge between wet and dry area?
Thanks.
Kiwon Um
Date: 9 Aug 2011 13:35:46
Message: <4e416ff2$1@news.povray.org>
Le 09/08/2011 18:15, kiwon nous fit lire :
>> each object.
No. It's either 1 or 0. Antialiasing might help anyway, but only at
pixel size.
If you need some more smoothness, it might be tempting to push in some
average pattern on top of many object pattern (with somehow variant
objects).
In fact, you would enjoy a proximity pattern... (sampling inside-test of
objects in a sphere around the object.. it would be smooth); but it's
not yet available.
I was just assuming that it's either wet or dry. Life is so complex.
Date: 9 Aug 2011 18:18:52
Message: <4e41b24c$1@news.povray.org>
>>> each object.
> pixel size.
> objects).
> not yet available.
Hmm. The issue there is probably more a case of "wet vs. damp vs. dry".
Not sure how that would work, since you need a darkening of the color
where its merely "damp", to match that of the wet part, but without the
reflective characteristics... But, yeah, life, sadly, is often more
complex than is easily managed in what is supposed to be a
photo-realistic rendering engine. lol
Date: 9 Aug 2011 22:05:00
Message: <web.4e41e5bda119247b4c0a951f0@news.povray.org>
Yeah... life is so complex to render...
Alright, if I manually generate a texture for wet area as saturation level or
something similar, how can I apply a special *finish* only to the wet area?
I tried like:
material {
  texture {T_Stone24 scale 0.3}
    pigment {uv_mapping image_map {png "wet.png"}}
    finish {phong 1 reflection {0.1, 1 fresnel} conserve_energy}
where "wet.png" is basically transparent except some wet areas.
It's syntactically renderable, but does not render what I intend; the *finish*
is applied to all surfaces, i.e. T_Stone24 as well.
Am I missing something?
