POV-Ray : Newsgroups : povray.general : constructing solid mesh from surface mesh Server Time
6 May 2026 07:54:17 EDT (-0400)
  constructing solid mesh from surface mesh (Message 1 to 10 of 13)
Subject: constructing solid mesh from surface mesh
Date: 21 Jul 2011 04:20:00
Message: <web.4e27dd1d8307f73b4c0a951f0@news.povray.org>
Dear POV-Ray users,
when there is only a surface mesh, is there any way to construct a solid
(volumetric) mesh covered by other solid object boundary such as box?
This codes are what I'm just trying, but doesn't seem to work:
  #declare mysurface = mesh2 {
    ... surface data
  #declare myvolume = union {
    box {0, 1 clipped_by {mysurface}}
    mysurface
Thanks
Tested in Persistence of Vision(tm) Ray Tracer Version 3.7.0.RC3
Issued: Parse Error: Illegal texture or patch in clip, bound or object pattern.
Subject: Re: constructing solid mesh from surface mesh
Date: 21 Jul 2011 04:40:31
Message: <4e27e5ff@news.povray.org>
  If you want to use an object in CSG, it has to be solid (ie. have a
well-defined interior). With meshes you can do this by adding an
inside_vector to it. (Refer to the documentation about meshes.)
Date: 21 Jul 2011 05:05:01
Message: <web.4e27eadffccc6bd34c0a951f0@news.povray.org>
Thanks for your reply. BTW, for my purpose, is there any advice?
Kiwon
Date: 21 Jul 2011 06:59:09
Message: <4e28067d$1@news.povray.org>
>      mysurface
Try:
   object {mysurface}
Date: 21 Jul 2011 08:30:04
Message: <web.4e281b84fccc6bd34c0a951f0@news.povray.org>
> >      mysurface
> Try:
>    object {mysurface}
Tried, but the same error msg on the "clipped_by" line:
The clipped_by doesn't seem to work with mesh2.
Date: 21 Jul 2011 08:45:01
Message: <web.4e281f1afccc6bd34c0a951f0@news.povray.org>
> > >      mysurface
> > Try:
> >    object {mysurface}
If I put *inside_vector y* (because the surface's average normal direction is y
direction) in mysurface, it seems to construct what I intend. But the rendering
result has noise on that solid mesh.
Date: 21 Jul 2011 10:11:03
Message: <4e283377$1@news.povray.org>
>>>       mysurface
>> Try:
>>     object {mysurface}
What about:
#declare myvolume =
intersection {
   box {0, 1}
   object {mysurface}
Date: 21 Jul 2011 11:30:01
Message: <web.4e28449efccc6bd39054ac430@news.povray.org>
That's not how inside_vector works.
It simply defines the specified point to be *inside* the object, thus
determining its inside and outside.
Date: 21 Jul 2011 11:40:01
Message: <web.4e284716fccc6bd34c0a951f0@news.povray.org>
> >>>       mysurface
> >> Try:
> >>     object {mysurface}
> What about:
> #declare myvolume =
> intersection {
>    box {0, 1}
>    object {mysurface}
Doesn't work. It keep only mysurface. The following are a simple test codes
for my purpose:
#version 2.7
global_settings {
  assumed_gamma 1.33
  max_trace_level 30
  right -x*image_width/image_height
  location <0.0, 2.2, 2.7>
  look_at <0.0, 0.5, 0.5>
light_source {
  <500, 500, -200>
  color rgb 1.3
#declare myF = finish {
  ambient 0
  diffuse 0
  phong 1
  phong_size 200
  reflection {
    0.01, 1
    fresnel on
  conserve_energy
#declare myT = texture {
  pigment { rgbf <0.9,0.3,0.3 0.95> }
  finish { myF }
#declare myI = interior {
  ior 1.33
  fade_distance 10
  fade_power 2
#declare myM = material {
  interior{myI}
  texture {myT}
#declare TestSurf = mesh2 {
  vertex_vectors {
    4,
    <0, 0.5, 0>,
    <1, 0.5, 0>,
    <0, 0.5, 1>,
    <1, 0.4, 1>,
  face_indices {
    2,
    <0, 1, 3>,
    <0, 3, 2>,
  inside_vector y
#declare TestVol = union {
  box{0, 1 clipped_by{TestSurf}}
  TestSurf
#declare TestObj = object {
  TestVol
  translate <-0.5, -0.5, -0.5>
  material {myM}
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6, 0.7, 1.0>]
      [0.7 rgb <0.0, 0.1, 0.8>]
plane {
  y, -0.2
    pigment { color rgb <1.0, 0.8, 0.6> }
    finish { ambient 0 diffuse 1 }
object {
  TestObj
  translate <0, 0.5, 0.5>
Date: 21 Jul 2011 11:50:01
Message: <web.4e28499cfccc6bd34c0a951f0@news.povray.org>
Really? I don't think so. Please check the manual *3.4.2.3.1 Solid Mesh* it
says:
To determine if a point is inside a triangle mesh, POV-Ray shoots a ray from the
point in some arbitrary direction. If this vector intersects an odd number of
triangles, the point is inside the mesh. If it intersects an even number of
triangles, the point is outside of the mesh. You can specify the direction of
this vector. For example, to use +z as the direction, you would add the
following line to the triangle mesh description (following all other mesh data,
but before the object modifiers).
  inside_vector <0, 0, 1>
This change does not have any effect on unions of triangles, these will still be
always hollow.
