POV-Ray : Newsgroups : povray.general : It's that time again: icc vs. gcc Server Time
5 Mar 2026 00:18:37 EST (-0500)
  It's that time again: icc vs. gcc (Message 1 to 10 of 15)
Subject: It's that time again: icc vs. gcc
Date: 24 Jun 2011 00:20:01
Message: <web.4e040fe599bfb2badcff099d0@news.povray.org>
This time it's icc 11.1 vs. gcc 4.4.5 on running in 64-bit Debian 6.0 on an
Athlon II x4 @ 2.8 GHz (because that's all I have). Povray 3.6.1 running the
benchmark.pov file.
These are the fastest times I could muster for each compiler:
gcc 4.4.5, -march=barcelona, -ffast-math -unroll-loops
  Parse Time:    0 hours  0 minutes  1 seconds (1 seconds)
  Photon Time:   0 hours  0 minutes 16 seconds (16 seconds)
  Render Time:   0 hours 13 minutes 23 seconds (803 seconds)
  Total Time:    0 hours 13 minutes 40 seconds (820 seconds)
icc 11.1, -march=core2
  Photon Time:   0 hours  0 minutes 18 seconds (18 seconds)
  Render Time:   0 hours 13 minutes 26 seconds (806 seconds)
  Total Time:    0 hours 13 minutes 45 seconds (825 seconds)
And just for fun:
gcc 4.4.5, -march=barcelona -ffast-math -unroll-loops -mfpmath=387
  Photon Time:   0 hours  0 minutes 21 seconds (21 seconds)
  Render Time:   0 hours 15 minutes 32 seconds (932 seconds)
  Total Time:    0 hours 15 minutes 54 seconds (954 seconds)
Povray official binary
  Photon Time:   0 hours  0 minutes 28 seconds (28 seconds)
  Render Time:   0 hours 23 minutes  3 seconds (1383 seconds)
  Total Time:    0 hours 23 minutes 32 seconds (1412 seconds)
Looks like gcc and icc are neck and neck, although I've read that icc still
compiles programs that run suboptimal pathways on non-Intel processors.
Subject: Re: It's that time again: icc vs. gcc
Date: 24 Jun 2011 00:29:51
Message: <4e0412bf$1@news.povray.org>
Wow. And isn't the 3.7 binary a bit slower than 3.6?
http://isometricland.com
Date: 24 Jun 2011 01:15:06
Message: <web.4e041ceabe614b62dcff099d0@news.povray.org>
I've not tested 3.7. I like doing other things on my computer while running
these things, so I used 3.6
Date: 25 Jun 2011 12:26:07
Message: <4e060c1f$1@news.povray.org>
Am 24.06.2011 07:13, schrieb jhu:
As you obviously have the icpc compiler suit installed, could you do me
a favor and try compiling & running 3.7 nonetheless, and give some feedback?
As for running, I'd be most interested in behaviour regarding photons;
I've been experiencing problems there with icpc-compiled POV-Ray 3.7
ever since, but haven't managed to get any feedback about whether it's a
freak problem limited to my machine or a general issue.
Date: 25 Jun 2011 13:20:01
Message: <web.4e061799be614b623cfdbf880@news.povray.org>
Okay. Do you want benchmark with resulting image or have me use it in general?
Date: 25 Jun 2011 18:51:51
Message: <4e066687$1@news.povray.org>
Am 25.06.2011 19:15, schrieb jhu:
Thanks for your help. No benchmark needed, please just do some runs of
photons scenes (e.g. scenes/advanced/balcony and
scenes/advanced/optics), keeping your eyes peeled for sporadic (yet from
my experience frequent) crashes in particular.
Date: 26 Jun 2011 07:12:23
Message: <4e071417@news.povray.org>
  If you compile a generic 386 binary, but otherwise use the optimizations,
is there any improvement over the official binary?
Date: 27 Jun 2011 00:20:01
Message: <web.4e0804a4be614b62dcff099d0@news.povray.org>
Compiling with icc (icpc) gives an error (no error with gcc though):
make[3]: Entering directory `/home/jhu/temp/povray-3.7.0.RC3/source/backend'
icpc -DHAVE_CONFIG_H -I. -I../..  -I../.. -I../../source -I../../source
-I../../source/base -I../../unix -I../../vfe -I../../vfe/unix -pthread
-I/usr/local/include  -pipe -Wno-multichar -Wno-write-strings -s -O3 -ip -xHost
-pthread -MT fnpovfpu.o -MD -MP -MF .deps/fnpovfpu.Tpo -c -o fnpovfpu.o `test -f
'vm/fnpovfpu.cpp' || echo './'`vm/fnpovfpu.cpp
.../../source/base/image/colourspace.h(445): warning #1125: overloaded function
"pov_base::GammaCurve::IsNeutral" is hidden by
"pov_base::PowerLawGammaCurve::IsNeutral" -- virtual function override intended?
    static bool IsNeutral(float gamma);
.../../source/base/image/colourspace.h(464): warning #1125: overloaded function
"pov_base::ScaledGammaCurve::IsNeutral" -- virtual function override intended?
    static bool IsNeutral(float factor);
/usr/include/c++/4.4.5/cmath(500): error: identifier "__builtin_fpclassify" is
undefined
        return __builtin_fpclassify(FP_NAN, FP_INFINITE, FP_NORMAL,
          detected during:
            instantiation of
"__gnu_cxx::__enable_if<std::__is_arithmetic<_Tp>::__value, int>::__type
std::fpclassify(_Tp) [with _Tp=float]" at line 65 of
"/usr/local/include/boost/functional/hash/detail/hash_float.hpp"
            instantiation of "size_t={unsigned long}
boost::hash_detail::float_hash_value(T) [with T=float]" at line 299 of
"/usr/local/include/boost/functional/hash/hash.hpp"
undefined
          detected during:
            instantiation of
std::fpclassify(_Tp) [with _Tp=long double]" at line 65 of
boost::hash_detail::float_hash_value(T) [with T=long double]" at line 309 of
compilation aborted for vm/fnpovfpu.cpp (code 2)
make[3]: *** [fnpovfpu.o] Error 2
make[3]: Leaving directory `/home/jhu/temp/povray-3.7.0.RC3/source/backend'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/home/jhu/temp/povray-3.7.0.RC3/source'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/jhu/temp/povray-3.7.0.RC3'
make: *** [all] Error 2
Date: 27 Jun 2011 11:21:37
Message: <4e08a001@news.povray.org>
>> a favor and try compiling&  running 3.7 nonetheless, and give some feedback?
> undefined
>            detected during:
>              instantiation of
> undefined
>            detected during:
>              instantiation of
Did you rebuild boost with icc first? This looks like boost is configured
for gcc, while the compiler is of course icc.
	Thorsten
Date: 27 Jun 2011 11:40:00
Message: <web.4e08a3e3be614b62f4bdd9650@news.povray.org>
>  Thorsten
Ok, guess I'll try that next.
