POV-Ray : Newsgroups : povray.general : Array of points for use with bicubic patch Server Time
5 Mar 2026 00:19:42 EST (-0500)
  Array of points for use with bicubic patch (Message 1 to 10 of 15)
Subject: Array of points for use with bicubic patch
Date: 25 Apr 2011 09:05:01
Message: <web.4db5716483b8d732964acb270@news.povray.org>
I am attempting to make a curtain out of bicubic patches. I want to create an
array which contains all the points, which is easy enough, but I'm not sure how
to then use the points in the patches.
This is the array I intend to use:
#declare BPatchPoints = array[4][16] {
  { //points for first patch }
  { //points for second patch }
  { //points for third patch }
  { //points for fourth patch }
Also, I'm wondering if I could use while loops to generate the points, which
would make it easier to add randomness. Again, I'm not sure how to go about
doing this, except perhaps using the loop to generate the array as well?
D103
Subject: Re: Array of points for use with bicubic patch
Date: 25 Apr 2011 10:14:20
Message: <4db581bc$1@news.povray.org>
Le 25/04/2011 15:04, D103 nous fit lire :
Have you read
> http://wiki.povray.org/content/Documentation:Tutorial_Section_3#Bicubic_Patch_Object
The corner of each grid should match. (aka, duplicate them)
The control points along the jointing line should also.
Do you really want to manage the 16 points of patch with 0-15, or use a
double index 0-3,0-3 instead ?
(array[n][4][4])
Or even simpler to understand: array[n][m][4][4]
n height
m width (as number of patch)
Date: 25 Apr 2011 19:30:00
Message: <web.4db603442d1676e497b020200@news.povray.org>
Le_Forgeron <jgr### [at] freefr> wrote:
> Have you read
Yes, I have, and with previous patches I used a similar method, but I'm trying
to find an easier way to control and change the points, for example, all the
points along a certain axis etc.
> (array[n][4][4])
> n height
Hadn't thought of that, thanks.
Supposing I set up such an array, could I use it like this:
#declare P1 = 1;
#declare P2 = 1;
#while(P1<=4&P2<=4)
  bicubic_patch {
    type 1 u_steps 5 v_steps 5
    BPatchPoints[1][1][P1][P2]
  bicubic_patch {
    BPatchPoints[2][2][P1][P2]
  bicubic_patch {
  bicubic_patch {
  #declare P1=P1+1;
  #if (P1=4)
    #declare P2=P2+1;
    #declare P1=1;
Something tells me this isn't going to work, but I think that's the general idea
there.
Date: 26 Apr 2011 12:22:48
Message: <4db6f158@news.povray.org>
D103 <nomail@nomail> wrote:
> #declare P1 = 1;
> #declare P2 = 1;
> #while(P1<=4&P2<=4)
>   #declare P1=P1+1;
>   #if (P1=4)
>     #declare P2=P2+1;
>     #declare P1=1;
>   #end
> #end
  That's a really complicated way of making a nested loop. What's wrong
with the regular way of doing it?
#declare P1 = 0;
#while(P1 < 4)
  #declare P2 = 0;
  #while(P2 < 4)
    #declare P2 = P2 + 1;
  #declare P1 = P1 + 1;
  (Note that array indices start from 0, not from 1.)
Date: 26 Apr 2011 20:20:00
Message: <web.4db761002d1676e4c734aecd0@news.povray.org>
> Have you read
This may also be relevant:
http://wiki.povray.org/content/Documentation:Reference_Section_4.1#Bicubic_Patch
http://wiki.povray.org/content/Documentation:Reference_Section_2.3#Array_Identifiers
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.8#What_about_nested_loops.3F
http://wiki.povray.org/content/Documentation:Contents
Tor Olav
http://subcube.com
Date: 26 Apr 2011 21:30:01
Message: <web.4db76e442d1676e4c734aecd0@news.povray.org>
> > Have you read
> > (array[n][4][4])
> > n height
> #declare P1 = 1;
> #declare P2 = 1;
> #while(P1<=4&P2<=4)
>   bicubic_patch {
>   bicubic_patch {
>   bicubic_patch {
>   bicubic_patch {
>   #declare P1=P1+1;
>   #if (P1=4)
>     #declare P2=P2+1;
>     #declare P1=1;
>   #end
> #end
> there.
Have a look at the code below.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.6;
#declare PatchesInWidth = 2;
#declare PatchesInHeight = 2;
#declare PatchPoints =
  array[PatchesInHeight][PatchesInWidth][4][4] {
        { < 0,  0,  0>, < 1,  0,  0>, < 2,  0,  0>, < 3,  0,  0> },
        { < 0,  0,  1>, < 1,  1,  1>, < 2,  1,  1>, < 3,  0,  1> },
        { < 0,  0,  2>, < 1,  1,  2>, < 2,  1,  2>, < 3,  0,  2> },
        { < 0,  0,  3>, < 1,  0,  3>, < 2,  0,  3>, < 3,  0,  3> }
        { < 3,  0,  0>, < 4,  0,  0>, < 5,  0,  0>, < 6,  0,  0> },
        { < 3,  0,  1>, < 4, -1,  1>, < 5, -1,  1>, < 6,  0,  1> },
        { < 3,  0,  2>, < 4, -1,  2>, < 5, -1,  2>, < 6,  0,  2> },
        { < 3,  0,  3>, < 4,  0,  3>, < 5,  0,  3>, < 6,  0,  3> }
        { < 0,  0,  3>, < 1,  0,  3>, < 2,  0,  3>, < 3,  0,  3> },
        { < 0,  0,  4>, < 1, -1,  4>, < 2, -1,  4>, < 3,  0,  4> },
        { < 0,  0,  5>, < 1, -1,  5>, < 2, -1,  5>, < 3,  0,  5> },
        { < 0,  0,  6>, < 1,  0,  6>, < 2,  0,  6>, < 3,  0,  6> }
        { < 3,  0,  3>, < 4,  0,  3>, < 5,  0,  3>, < 6,  0,  3> },
        { < 3,  0,  4>, < 4,  1,  4>, < 5,  1,  4>, < 6,  0,  4> },
        { < 3,  0,  5>, < 4,  1,  5>, < 5,  1,  5>, < 6,  0,  5> },
        { < 3,  0,  6>, < 4,  0,  6>, < 5,  0,  6>, < 6,  0,  6> }
#declare PatchTextures =
  array[PatchesInHeight][PatchesInWidth] {
          checker
          color rgbf <1.0, 1.0, 1.0, 0.6>
          color rgbf <0.0, 0.0, 0.0, 0.6>
          checker
          color rgbf <0.7, 0.0, 0.0, 0.6>
          checker
          color rgbf <0.0, 0.7, 0.0, 0.6>
          checker
          color rgbf <0.0, 0.0, 0.7, 0.6>
#declare CntH = 0;
#while (CntH < PatchesInHeight)
  #declare CntW = 0;
  #while (CntW < PatchesInWidth)
    bicubic_patch {
      type 1
      flatness 0.001
      u_steps 4
      v_steps 4
      uv_vectors
        <0, 0>
        <1, 0>
        <1, 1>
        <0, 1>
      #declare I = 0;
      #while (I < 4)
        #declare J = 0;
        #while (J < 4)
          PatchPoints[CntH][CntW][I][J]
          #declare J = J + 1;
        #end // while
        #declare I = I + 1;
      #end // while
      uv_mapping
          PatchTextures[CntH][CntW]
          scale 1/3
    #declare CntW = CntW + 1;
  #end // while
  #declare CntH = CntH + 1;
#end // while
background {
  color rgb 0.5*<1, 1, 1>
  location <3, 6, -3>
  look_at <3, 0, 3>
light_source {
  500*<1,  1, -1>
  color rgb <1, 1, 1>
  shadowless
Date: 27 Apr 2011 08:05:00
Message: <web.4db805432d1676e49f865aaa0@news.povray.org>
> Tor Olav
> #version 3.6;
>       texture {
>         pigment {
>           checker
>       texture {
>         pigment {
>           checker
>       texture {
>         pigment {
>           checker
>       texture {
>         pigment {
>           checker
> #declare CntH = 0;
>   #declare CntW = 0;
>     bicubic_patch {
>       type 1
>       flatness 0.001
>       u_steps 4
>       v_steps 4
>       uv_vectors
>         <0, 0>
>         <1, 0>
>         <1, 1>
>         <0, 1>
>       #declare I = 0;
>       #while (I < 4)
>         #declare J = 0;
>         #while (J < 4)
>           #declare J = J + 1;
>         #end // while
>         #declare I = I + 1;
>       #end // while
>       uv_mapping
>         texture {
>           scale 1/3
>   #end // while
> #end // while
> background {
> camera {
>   location <3, 6, -3>
>   look_at <3, 0, 3>
> light_source {
>   500*<1,  1, -1>
>   color rgb <1, 1, 1>
>   shadowless
That's great! Took me a while to understand the nested loops though.
Thank you very much.
The other reason I posted was to ask if there was a way to reduce the process of
creating the vectors for the patches to a while loop or nested loops.
Call me lazy, but I'm always looking for shorter/easier ways to do things. :)
D103
Date: 27 Apr 2011 09:20:00
Message: <web.4db816822d1676e447ba06bb0@news.povray.org>
Coding in order to being able to be lazy later is a good thing.
Being lazy while coding is a bad thing.
- And yes, there are ways to do what you want.
Perhaps these 2 images will give you some hints or ideas:
http://home.online.no/~t-o-k/POV-Ray_Images/Bezier_Patches_Stitched.jpg
http://home.online.no/~t-o-k/POV-Ray_Images/Bezier_Patches_Stitched_.jpg
Tor Olav
http://subcube.com
Date: 3 May 2011 08:40:00
Message: <web.4dbff7222d1676e4dd10c23d0@news.povray.org>
> D103
After some experimentation, I have come up with these loops.
The idea is of course, to replace the sphere with an array or to place the loops
within an array, whatever is necessary.
#declare X1=-1.5;  //in the scene file these are equal to the v_length of the
appropriate values.
#declare Z1=-1.5;
#declare Cnt=0;
#while(X1<=1.5)
  #while(Z1<=1.5)
    #if(Cnt>=15)
      #debug "Cnt = illegal value.\n"
    #else
      #debug "Cnt is within legal range.\n"
    //#declare Pts[Cnt]=<X1, 0, Z1>;
    sphere { 0, 0.1 pigment { White } translate <X1, 0, Z1> }
    #declare Z1=Z1+1;
    #declare Cnt=Cnt+1;
For some reason, when I run this in POV-Ray, it only creates one sphere, (or
else several spheres in the same location), and when the sphere is replace with
an array, the first point is generated alright, but on the second loop, it
produces an error message: "attempt to access uninitialized array element".
  #declare X1=X1+1;
  #declare Z1=-1.5;
If someone could point out the problem(s), I would be very grateful.
Thanks,
D103
Date: 3 May 2011 11:20:04
Message: <4dc01d24@news.povray.org>
> appropriate values.
> #declare Z1=-1.5;
> #declare Cnt=0;
> #while(X1<=1.5)
>   #while(Z1<=1.5)
>     #if(Cnt>=15)
>     #else
>     #end
>     #declare Z1=Z1+1;
>     #declare Cnt=Cnt+1;
>   #end
>   #declare X1=X1+1;
>   #declare Z1=-1.5;
> #end
  You seem to have very complicated ways of performing nested loops.
What's wrong with the traditional way of doing nested loops? In other
words:
#declare Cnt = 0;
#declare X1 = -1.5;
#while(X1 <= 1.5)
  #declare Z1 = -1.5;
  #while(Z1 <= 1.5)
    #declare Z1 = Z1 + 1;
    #declare Cnt = Cnt + 1;
  #declare X1 = X1 + 1;
