POV-Ray : Newsgroups : povray.general : Colour in shadow! Server Time
16 May 2025 23:20:19 EDT (-0400)
  Colour in shadow! (Message 1 to 3 of 3)
Subject: Colour in shadow!
Date: 10 Apr 2011 19:50:00
Message: <web.4da2416e42a4b003413a4eea0@news.povray.org>
i have created a object with the following code:
#declare Window =
union{
  box{<0,0,0.1>,< 1.50,1.50,0.1>
        pigment {image_map { png "net.png"}}
  box{<0,0,0.11>,<1.5,0.05,0.21>}
  box{<0,1.50,0.11>,< 1.50,1.55,0.13>}
  box{<0,0,0.11>,<0.05,1.50,0.13>}
  box{<1.50,0,0.11>,<1.55,1.50,0.13>}
  box{<1.50,1,0.11>,<0,1.05,0.13>}
        pigment{ color White}
        finish { ambient 0.9 phong 0.5}
and called with
object{ Window
        scale <1,1,1>*1
        rotate<0,0,0>
        translate<4,2.3,2.401>
        rotate y*90}
This creates a window that looks exactly how i want it, the only thing being
that, when the window is in the shadow of something, eg a tree im trying to do,
it still stays bright white rather than going dull, does anyone know how to do
this?
Subject: Re: Colour in shadow!
Date: 11 Apr 2011 00:42:18
Message: <4da286aa$1@news.povray.org>
> this?
Your ambient is too high, try values between 0 and 0.3.
Regards
Date: 11 Apr 2011 13:20:40
Message: <4da33868@news.povray.org>
> #declare Window =
> union{
>          texture {
>    texture {
> and called with
> object{ Window
>          scale<1,1,1>*1
>          rotate<0,0,0>
>          rotate y*90}
> this?
Don't use ambient!
If you use version 3.6, use double_illuminate in your finish for your
window. That way, it will get it's illumination from the light reatching
it's back side.
Way beter, but you beed version 3.7, is to use the new backside diffuse
illumination.
To use it, you change the diffuse value like this:
finish { ambient 0 diffuse 0.1, 0.9 }
Also add interior_texture{pigment{rgbt 1}} to the boxes making your
glass. This is advisable with both double_illuminate anf the backside
diffuse illumination.
texture{
	pigment{White}
	finish{ambient 0 diffuse 0.1 0.9}
interior_texture{ pigment {rgbt 1}}
