Hi!
I have a huge scene where I have many many objects with glowing media inside
"interior { media { emission <0.6,0.8,1>*.05 } }". How can I create a shine
around these glowing objects without post processing? Can this be done with fog
or media? The Light-saber approach where one needs to create a larger version of
these objects, putting some other media inside would not be possible for me.
Any Ideas anyone?
"CAD-Andi" <nomail@nomail> schreef in bericht
news:web.4d857a70705a2775b642fbb20@news.povray.org...
> Hi!
> inside
> shine
> with fog
> version of
> me.
> Any Ideas anyone?
I am working on a night scene with halos around light sources. I use an
emission media with a spherical density.
Am 20.03.2011 04:54, schrieb CAD-Andi:
> "interior { media { emission<0.6,0.8,1>*.05 } }". How can I create a shine
The latter would be the usual way to go though.
Another approach would be to place the camera inside a transparent
sphere with ior, and add an averaged texture in front: One (stronger)
sub-texture being totally invisible, the other (weaker) sub-texture
having high-frequency perturbed normals. To be used with strong
anti-aliasing or focal blur. However, this approach is only useful for
creating halos around exceptionally bright objects.
> Thomas
Hi Thomas!
Do you happen to have a small code example to get me started? Would be awesome!
Andi
> Hi!
> Any Ideas anyone?
The normal way is to add some slightly larger object around the
concerned object and fill that with a media using a spherical or
cylindrical pattern.
Fog can't do what you want.
The outer object don't need to ba a larger version of your object. It
just need to surround the part(s) you want to shine.
The fact that your scene is huge and that there are many glowing objects
will make this tedious.
Clipka's suggestion looks promising, but will be computionaly intensive.
It may be possible to place refractive objects with averaged normals
around your glowing objects. Low ior (no more than 1.1) and STRONG
normals, NO reflection and NO highlight on those.
This way, the added computations are limited to the area surrounding the
glowing objects.
It will render slower than the added emissive media objects.
Am 20.03.2011 17:52, schrieb Alain:
> glowing objects.
Slowdown can also be mitigated to some degree by adding "no_shadow
no_reflection no_radiosity" to those refractive objects.
news:web.4d8600f95784deadb642fbb20@news.povray.org...
>> Thomas
> Hi Thomas!
> awesome!
Of course. This is the code I use.
//-----------------------------------------------start code
#local HaloScale = 100;
#local colLum = rgb <1.0, 1.0, 0.9>; // light color
#local haloTurb = 0.1; // outer halo turbulence
#local haloStrength = 0.5; // inner and outer halo intensity
(outer halo is 50% inner halo intensity)
#local DensityShift = 0.9; // shifts the density within the media
#local DensityHalo =
density {
spherical
turbulence haloTurb
color_map {
[0.4 rgb 0]
[0.8 colLum*haloStrength*0.05]
[1.0 colLum*haloStrength*0.5]
scale <1, 1, 1>
translate DensityShift*y
#local mediaHalo =
media {
emission haloStrength*0.5
intervals 1
samples 100
confidence 0.9999
variance 1/10
density {DensityHalo}
#declare LampHalo =
sphere {0, 1
texture {pigment {rgb 0 transmit 1} finish {ambient 0 diffuse 0}}
interior {media {mediaHalo}}
hollow no_shadow
translate -DensityShift*y
scale HaloScale
translate <-0.09911, 1.861, 0.0> //locate halo center a bit within the
lamp shade
#declare LampHalo2 =
sphere {0, 1
interior {
media {
scattering {1, (colLum*0.05)/200}
hollow no_shadow
scale 200
translate <Max.x, Max.y, 1>
#macro Lamp(Force,Area,FD)
light_source {
<-0.6221, 3.953, 0.0>,
colLum*Force
#if (Area)
area_light
<1.0, 0, 0> <0, 0, 1.0>
3, 3
adaptive 1
jitter
circular
orient
fade_distance FD
fade_power 2
//looks_like {sphere {0, 1.0 pigment {rgb <1,1,1>} finish {emission 1}}}
#end //of macro
//-----------------------------------------------end code
