POV-Ray : Newsgroups : povray.general : Idea regarding crevice grime Server Time
18 Aug 2025 16:13:07 EDT (-0400)
  Idea regarding crevice grime (Message 1 to 9 of 9)
Subject: Idea regarding crevice grime
Date: 9 Mar 2011 12:35:00
Message: <web.4d77ba1f8499cdd581c811d20@news.povray.org>
Robert McGregor's recent comments on using AO for grime layers tweaked me
thinking about how to achieve an object pattern that could do this.  I was
thinking along the lines that we have slope and aoi patterns for example that
depend upon the object surface itself, would it be possible to have a pattern
that basically for any given surface point, shoots a trace ray or the like,
normal out from the surface and returns the value or a function based on
distance to self-intersection, likely an inverse function ranging from no
intersection=0 (1/inf=0) to immediate=1 (0/1=0).
Does this sound like something doable without unacceptable increase in render
overhead?
-tgq
Subject: Re: Idea regarding crevice grime
Date: 10 Mar 2011 18:50:12
Message: <4d7963b4$1@news.povray.org>
IME, the best (not to mention the most accessible) way to do this is to
use a proximity pattern, which is basically just an object pigment
blurred in 3D space. The advantage of using proximity patterns is that
you can obtain *outside*edge* data as well as inside edge data.
Any other AO-like ray tracing/casting method would require some new
routines to be added into POV's rendering core... but I could be wrong.
(anything can be done if you're willing to wait through a long render)
Look for anything related to "proximity patterns." It might not be the
most efficient method for adding "crevice grime" to objects, but you can
always bake the effect into meshes using POV-Ray 3.7b.
Good luck!
Sam
Date: 12 Mar 2011 02:55:12
Message: <4d7b26e0$1@news.povray.org>
Am 11.03.2011 00:50, schrieb stbenge:
Trevor's idea was actually the path I followed with my earlier attempt
at a proximity pattern. Code-wise it was not much of a change, as
radiosity already has everything that's needed, even including some
optimization. However, it could not do outside edges, and the approach
also didn't allow for choosing only a subset of objects to affect the
pattern - it would always use the complete scene.
My next attempt would probably be based on the "blurred object"
approach; syntax-wise it might even be a simple extension to the object
pattern. But don't hold your breath.
Date: 12 Mar 2011 08:40:00
Message: <web.4d7b76e57795d8a3b05ef170@news.povray.org>
My thought was that it could be implemented as a pattern type where it is object
based.  One slight issue with my idea is that if you only use the direct normal,
it would fail at the very valley of a crevice as the normal ray would come
straight back out without intersection.  This could maybe be solved by not using
the normal, but perhaps an average of a few normals some angle from
perpendicular (eg 45deg) that would intersect.
I don;t see the issue with outside edges, as what I think of as grime tends to
be only on interior edges or crevices; that is surface areas that are not
exposed.
I would look at trying to code this myself, but I'm not really up to snuff yet
with the internal POV coding.  Maybe in the future if I have time, I may look at
it and a few other things, but for now just throwing it out there as ideas for
those that are playing at the code.  Would be nice to see if you can come up
with something.
-tgq
Date: 12 Mar 2011 12:01:36
Message: <4d7ba6f0$1@news.povray.org>
Am 12.03.2011 14:36, schrieb Trevor G Quayle:
> exposed.
While crevices might accumulate grime, prominent edges might show the
effects of handling; e.g. an otherwise dull and oxidized metal object
might be polished at prominent edges (think of a brass statue). A
proximity pattern that could account for that as well would be a good thing.
Date: 12 Mar 2011 13:50:01
Message: <web.4d7bc00b7795d8a3b05ef170@news.povray.org>
> > exposed.
I guess that's true.  Maybe there's a need for two pattern types then, or at
least the ability to choose either/or.
-tgq
Date: 12 Mar 2011 14:02:11
Message: <4d7bc333$1@news.povray.org>
>>> exposed.
By default a proximity pattern is both combined, so one only has to
adjust the color_map to choose between one or the other. This choosing
ability could be in the form of two macros in an #include file somewhere...
Sam
Date: 12 Mar 2011 14:13:12
Message: <4d7bc5c8@news.povray.org>
Wasn't there also an issue with how radiosity precaches samples on a
screen-level basis, which was in turn causing the prox pattern to give
different results depending on the camera location/screen size/etc.?
I won't, but I am wondering how you plan to approach the problem...
Sam
Date: 12 Mar 2011 14:27:22
Message: <4d7bc91a$1@news.povray.org>
Am 12.03.2011 20:13, schrieb stbenge:
No.
Essentially the same as those macros used, by jittering an object
pattern. Implementing this as an intrinsic feature is likely to allow
for some performance improvements, such as adaptive sampling of the
object pattern, and re-using cached samples similar to what's done for
radiosity.
