POV-Ray : Newsgroups : povray.general : Transform to a spline without loop-de-loops Server Time
5 Mar 2026 01:51:45 EST (-0500)
  Transform to a spline without loop-de-loops (Message 1 to 10 of 10)
Subject: Transform to a spline without loop-de-loops
Date: 8 Mar 2011 22:05:00
Message: <web.4d76ee3b27f8363e34d207310@news.povray.org>
I'm not posting (soley) to brag about an animation.  I've got my character
walking system set up to walk along any spline, so I figured I'd try it in 3D. I
found code for the curve of a baseball seam and set it to go:
http://www.youtube.com/watch?v=Fh2pIMN3ZlQ
Does anyone have any ideas on how I can prevent the loop-de-loops? I'd like to
have it always pointing outwards from the circle.
Given a bodypath spline, I go:
#declare bodypos0=<0,0,0>+bodypath(clock) ;  // the bo
#declare bodypos1=<0,0,0>+bodypath(clock+1e-4);
#declare bodylocalz=bodypos1-bodypos0;
#declare bodylocalx=vcross(-y,bodylocalz);
object{body  Reorient(z+0.0001,bodylocalz)  translate bodypos0 }
I guess my problem is in my vcross statement.
Subject: Re: Transform to a spline without loop-de-loops
Date: 8 Mar 2011 22:50:00
Message: <web.4d76f8ad48e6ef7eb05ef170@news.povray.org>
Looks pretty good.
I'm not certain, but one thing that you are doing that may make a minor
difference, is that you are basing the orientation on a vector from the current
position to one slightly ahead (bodylocalz).  I would (as I do with procedural
meshes) use one point behind and one ahead as my forward vector, which should be
approximately close to the tangent of the current point.
-tgq
Date: 9 Mar 2011 03:38:17
Message: <4d773c79$1@news.povray.org>
what is your vector base ? (right, up, depth ?)
it seems so far that z is the horizontal direction.
x might be the vertical one ? or is it y ?
you do not use bodylocalx, so vcross is not the issue.
If you want to avoid loop-de-loops, (if I got that correctly), it just
means that you want to fix one vector (y ? well the line of shoulders)
and have a planar rotation (along the depth vector) only. If you
normalise bodylocalz, you can ask atan2 the angle needed for that
rotation (comparing to an implicit z), and then perform the rotation.
That would be fine for 2D spline.
Also, beware of z+0.0001 ... it's <0.0001, 0.0001, 1.0001> !
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 9 Mar 2011 07:40:01
Message: <web.4d77743e48e6ef7e34d207310@news.povray.org>
Thanks for the advice all.
Ah, you leave code lying around for a while and sometimes you forget what's
active.
This I found to be necessary for any use of Reorient. If you transform from z to
z, it bombs out with singular matrix in inverse thing.  Not helpful.
> which should be approximately close to the tangent of the current point.
I don't think this is a universal solution. I'd like it to work for any spline,
whether it's ten points widely spaced along a natural_spline curve, or one
defined with a thousand points set up via trig functions.  I had an application
where I wanted it to walk around obstacles, and so I only needed to set up ten
points that avoided the obstacles. "Next point" would disrupt that system.
Date: 9 Mar 2011 07:46:25
Message: <4d7776a1$1@news.povray.org>
Am 09.03.2011 04:04, schrieb gregjohn:
No, the problem is that you don't /use/ that vcross statement ;-)
Presuming that "Reorient" is a copy of "Reorient_Trans" from
transforms.inc, the macro doesn't give you enough control over the
transformation: It makes sure that what originally points to z+0.0001
(BTW, why not just z?) is now pointing to bodylocalz, but takes the
freedom to mess with all the other axes involved in order to achieve this.
For more control, compute all the new axis directions (X, Y and Z)
yourself, and use the Shear_Trans macro, i.e.:
   #include "transforms.inc" // or copy the macro to your code
   #declare bodylocalz = vnormalize(bodypos1-bodypos0);
   #declare bodylocaly = vnormalize(bodypos0-Center);
   #declare bodylocalx = vcross(bodylocaly,bodylocalz);
                  // or -vcross(bodylocaly,bodylocalz);
   object {
     body
     Shear_Trans(bodylocalx,bodylocaly,bodylocalz)
     translate bodypos0
Date: 9 Mar 2011 08:31:30
Message: <4d778132$1@news.povray.org>
Am 09.03.2011 13:36, schrieb gregjohn:
>> Also, beware of z+0.0001 ... it's<0.0001, 0.0001, 1.0001>  !
I guess if you leave it like that, tansforming may still bomb in case
the new vector happens to be z+0.0001.
I guess his suggestion is to use
   #declare bodypos0=<0,0,0>+bodypath(clock-1e-4); // (!!!)
which doesn't really harm what you're doing, and should indeed typically
be closer to the tangent.
Date: 10 Mar 2011 07:25:01
Message: <web.4d78c28148e6ef7e34d207310@news.povray.org>
Thanks for the elegant fixes suggested.  Your code however bombed out after
about 80 frames to to the singular matrix inverse problem.  I had to fix the
Shear_Trans macro to be that below.  For some reason, I end up with guys facing
forward (+Z) in my work.
#macro Shear_Trans(A, B, C)
   transform {
      matrix < A.x, A.y, A.z,
             B.x, B.y, B.z,
             C.x, C.y, C.z+.000001,
             0.00001, -0.000002, 0>
Date: 12 Mar 2011 03:02:15
Message: <4d7b2887$1@news.povray.org>
Am 10.03.2011 13:22, schrieb gregjohn:
I don't see why this should happen, unless at some point your spline
heads straight at (or away from) the center.
Also note that the code I proposed presumes that your spline lies on
(sufficiently close to) the surface of a sphere around the center.
> I had to fix the
Again you're just suppressing the problem for a particular scene, still
risking bombing in others, rather than really fix it.
That's just strange.
Date: 12 Mar 2011 09:10:00
Message: <web.4d7b7dee48e6ef7e34d207310@news.povray.org>
What causes the "singular" matrix error in Shear_Trans?  If it is that it is
unable to shear from <a,b,c> to <a,b,c>, then isn't it possible to add some
"epsilons" to the matrix and prevent that problem?
> > I had to fix the
Date: 12 Mar 2011 12:08:09
Message: <4d7ba879$1@news.povray.org>
Am 12.03.2011 15:06, schrieb gregjohn:
> unable to shear from<a,b,c>  to<a,b,c>, then isn't it possible to add some
That wouldn't really be a reliable solution - because any epsilon you
might add would just shift the problem to other parameter combinations.
AFAIK, a "singular" matrix error indicates that the generated matrix
represents a transformation that collapses the resulting object from 3D
to 2D - in other words, a shearing transformation where either (a) one
of the new axes is zero, (b) two of the new axes are collinear, or (c)
the three new axes are coplanar (i.e. lie in the same plane).
