POV-Ray : Newsgroups : povray.general : Floating point accuracy Server Time
6 May 2026 09:20:28 EDT (-0400)
  Floating point accuracy (Message 1 to 6 of 6)
Subject: Floating point accuracy
Date: 8 Feb 2011 14:35:00
Message: <web.4d519a04579fd3e9d7f39bd00@news.povray.org>
One of my works in progress is an orbital view of a planet with a satellite at
relatively close range.  The problem is that I need a fairly fine detail on the
satellite, so I've modeled it at 1 unit = 1 inch, but a planet of the same scale
doesn't render properly.
So I'm fishing for suggestions.
A.D.B.
Subject: Re: Floating point accuracy
Date: 8 Feb 2011 14:43:15
Message: <4d519cd3$1@news.povray.org>
Am 08.02.2011 20:31, schrieb Anthony D. Baye:
> Regards,
> A.D.B.
Scale the whole scene down? Just because you've modelled a satellite at
1 unit = 1 inch doesn't mean you can't just "scale 0.01" it ;-)
Fake it, scaling down the planet and moving it closer to compensate?
Render the planet separately using a spherical camera, and then using
that as a sky sphere?
Date: 8 Feb 2011 15:29:05
Message: <4d51a791@news.povray.org>
One thing that works for me is to create two scenes. In one scene,
render the planet very small, with a correspondingly small camera angle.
Copy the camera settings into another scene file, but with a new,
desired camera angle. Map the image of the planet onto a box using
Rune's illusion.inc.
Sam
Date: 8 Feb 2011 15:36:52
Message: <4d51a964$1@news.povray.org>
That's what I'd do. :-D
Regards
Date: 9 Feb 2011 03:28:28
Message: <4d52502c@news.povray.org>
"Stephen" <mcavoys_at@aoldotcom> schreef in bericht
news:4d51a964$1@news.povray.org...
Me too, and you only have to determine the apparent size of the planet. You
probably can calculate it, but I did it once in Moray just by moving spheres
around :-)
Date: 10 Feb 2011 11:55:12
Message: <4d541870@news.povray.org>
  If you scale the planet down several orders of magnitude and move it
closer, it will look identical.
