POV-Ray : Newsgroups : povray.general : Plywood texture Server Time
6 May 2026 10:51:56 EDT (-0400)
  Plywood texture (Message 1 to 7 of 7)
Subject: Plywood texture
Date: 27 Jan 2011 23:30:01
Message: <web.4d4245ad96e2ba37b86a4a720@news.povray.org>
I'm trying to model a plywood texture and was hoping someone here would have
some insight for me.
The problem I am having is due to the way light interacts with end-grain in wood
(it looks darker.)  This makes the edge of plywood have darker looking plys
between plys that are the same colour as the plywood surface.  Further, those
same dark plys on one edge are light on the adjacent edge (and the light ones
are dark.)  The same really goes for pretty well any wood but it is quite
obvious with plywood.
Thanks,
Mike
Subject: Re: Plywood texture
Date: 28 Jan 2011 12:08:08
Message: <4d42f7f8$1@news.povray.org>
Le 28/01/2011 05:27, Solar Mike nous fit lire :
Not all plywood, not every cut.
Darkness/lightness is due to the orientation of the fibers in regards to
the cut.
Use the cubic pattern at the root of your texture.
Then for each of the 6 faces, provide the pattern that you want
(including a shifted pattern for the adjacent edge, or a reversed map...)
Scale & translate the cubic as needed.
Date: 28 Jan 2011 13:10:00
Message: <web.4d430550ae170778a6a53d210@news.povray.org>
> the cut.
Thanks for responding.
You are quite right about not all plywoods working this way and is indeed due to
the fiber orientation.  I was hoping to find a more general solution as many of
the pieces I have will have curves "cut" in them.  This problem shows itself on
plain (but curved) pieces of wood I am trying to render as well and I have not
figured out a good way of dealing with that.
Typically, I see these issues when doing CSG operations.
Date: 28 Jan 2011 14:30:47
Message: <4d431967$1@news.povray.org>
Le 28/01/2011 19:05, Solar Mike nous fit lire :
>> the cut.
Have you then checked the slope pattern instead ?
Date: 28 Jan 2011 15:29:39
Message: <4d432733@news.povray.org>
Am 28.01.2011 19:05, schrieb Solar Mike:
I'd suggest some nested construct:
Use a high-frwequency gradient pattern to simulate the layering of the
plywood, alternating between two differently oriented versions of the
main texture, depending on Y coordinate (presuming your plywood board is
in the XZ plane).
To simulate the orientation dependency of the texture within each
plywood layer, use a radial sine_wave frequency 2 pattern to blend
between two textures with different brightness and whatever other
properties you may want to vary.
Date: 28 Jan 2011 16:43:10
Message: <4d43386e$1@news.povray.org>
Le 28/01/2011 20:30, Le_Forgeron nous fit lire :
Have a look at p.b.i & p.b.s-f for a small test in gold.
Date: 28 Jan 2011 22:25:01
Message: <web.4d438887ae170778b86a4a720@news.povray.org>
Thanks,
I think slope was pretty well what I was looking for except that I was hoping
the direction vector given would get transformed along with the object it was
applied to.  As your scene points out though, having light and dark layers
provides a pretty reasonable approximation. :)
Mike
