POV-Ray : Newsgroups : povray.general : help with splines Server Time
5 Mar 2026 03:54:29 EST (-0500)
  help with splines (Message 1 to 10 of 11)
Subject: help with splines
Date: 9 Dec 2010 12:40:01
Message: <web.4d01143d847db539663718460@news.povray.org>
So I'm making a simple roller coaster animation. I have one car and can make it
move around the track using Spline_Trans. The problem is that now I want to make
multiple roller cars and since my spline doesn't have constant distances between
each time value I can't get the roller cars to always be the same distance from
each other.
Here is my animation so far:
http://i1233.photobucket.com/albums/ff392/yoyodunno/coasterAnimation-1.gif?t=1291916196
As you can see the speed is not constant because the distance over the spline
time values isn't constant.
Is there something I can do to make the distance values constant over each time
value in the spline so that the animation has constant speed, which will also
let me make multiple carts. I realize I could make a high framerate animation,
and then play with the frames to get this to work, but I hope I don't have to go
there.
Thanks.
Subject: Re: help with splines
Date: 9 Dec 2010 12:55:12
Message: <4d0117ff@news.povray.org>
  Distributing points at even distances on a spline is a non-trivial problem
because of how a spline is calculated. I don't know if there exists a
closed form expression for this (in other words, a single non-recursive
formula which can be used to calculate a point at a given length from the
beginning of the spline without resorting to an iterative approximation),
but the most common approach to this is to approach the problem iteratively.
In other words, when you want a point on the spline which is at a distance
x from the beginning of the spline, you sample points on the spline,
approximate their distance from the beginning, and then use something
like binary partitioning to get a point arbitrarily close to the actual point
you are searching.
  IIRC Colefax's spline macro utility had such a functionality built-in
(but it's not related to the splines in POV-Ray 3.6).
Date: 10 Dec 2010 13:05:01
Message: <web.4d026b2e464c1137cd2e0a0a0@news.povray.org>
> you are searching.
How do I sample points along the spline? Is there some command to get a point on
the spline or something? Also I have no idea what binary partitioning is, but
I'll look it up.
Date: 11 Dec 2010 08:00:01
Message: <web.4d0374a3464c1137c734aecd0@news.povray.org>
> > you are searching.
> >                                                           - Warp
> I'll look it up.
The spline macro that Warp mentioned above can now be found here:
http://povrayinclude.wytraven.com/spline/index.html
Tor Olav
http://subcube.com
Date: 11 Dec 2010 14:30:00
Message: <web.4d03d077464c1137cd2e0a0a0@news.povray.org>
Ok so I tried sampling points along the spline like this:
#declare curve_Vectors=0;
     //try to average curve length with averaging vectors
     #declare curve_loop=2;
        #while(curve_loop<11)
                #declare
curve_Vectors=curve_Vectors+vlength(spline_A(Nr+(stepValue*curve_loop))-spline_A(Nr+(stepValue*(curve_loop-1))));
                #declare curve_loop=curve_loop+1;
     #declare curve_Average=curve_Vectors/9; //try to get average length of 9
subdivisions
     #declare CumulativeDistance=CumulativeDistance+curve_Average;
      object{tracks Spline_Trans(spline_A,CumulativeDistance,y,.1,.8)}
So it does give slightly better spaced tracks, I made that while loop to try and
average more vectors along the spline and it also helped slightly. But still not
that much better than originally.
Is there anything else to give a better approximation of the curve distance? And
yeah that colefax macro didn't work for what I have since I'm using a natural
spline, and also the Spline_Trans macro.
Date: 11 Dec 2010 15:45:49
Message: <4d03e2fd$1@news.povray.org>
> beginning of the spline without resorting to an iterative approximation)...
About a decade ago I looked into something like this.  Measuring the
length of a section of spline involves the integral of the length of the
differential of the...  Uh, it's complicated.  Even for a quadratic
spline the integral is hairy enough, and I suppose for a cubic spline
it's downright ugly.  The iterative solution is much neater and simpler
to understand.
John
Date: 11 Dec 2010 20:25:01
Message: <web.4d0423b9464c1137cd2e0a0a0@news.povray.org>
> to understand.
> Regards,
> John
Yeah, arc length in calculus, I was thinking about that! But, I've decided it's
too involved for me right now lol. So instead, I worked on getting the time
values so that the distances are almost uniform on the spline, I have it pretty
close so that now I should be able to have multiple roller cars without looking
too weird scrunching up or stretching out in the animation. Now time to add the
ferris wheel!
Date: 12 Dec 2010 10:15:00
Message: <web.4d04e5ed464c1137c734aecd0@news.povray.org>
>                 #declare
>         #end
> subdivisions
See my recent posts to povray.binaries.images and povray.text.scene-files
Tor Olav
http://subcube.com
Date: 17 Dec 2010 11:01:00
Message: <80dst7-3ns.ln1@badulaque.reducto>
Tor Olav Kristensen saw fit to write:
Have you tried creating a new spline that is already arc-length-
parametrized? Something like what's described here:
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.87.9080&rep=rep1&type=pdf
This seems a different method, but less appropriate for POV-Ray splines:
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.84.1389&rep=rep1&type=pdf
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 17 Dec 2010 12:55:44
Message: <4d0ba420$1@news.povray.org>
> differential of the... Uh, it's complicated. Even for a quadratic spline
> the integral is hairy enough, and I suppose for a cubic spline it's
> downright ugly. The iterative solution is much neater and simpler to
> understand.
> Regards,
> John
I've been using splines to control the path of a piece of chain, which
requires that the specified length segments follow the arc. I recognized
that you can do this 3 ways:
1) Define the start point, path, end point, and let it add as many
segments as is needed to follow.
2) Define the start point, path, and number of segments, and guess where
it ends up.
3) Define the start point, end point, and number of segments, and use
some sort of approximation to make the path.
Of these, #3 is computationally expensive and doesn't really give what
you're looking for anyway, and #1 and #2 requires the computations that
this thread is about, which are hard. So I came up with:
4) Define start point, derivative of the path, and number of segments.
This approach is computationally trivial and with some tweaking will
give you almost exactly what you're looking for. I made the macro
calculate the distance between each segment of the chain (variable
length per unit for the heck of it), then it takes the derivative path
function as a parameter. Each step it finds the direction to move by
normalizing the spline entry at that index, increments the "current
position" variable, rotates the segment to fit the direction and then
translates to the new position. Yes, it's a numerical integrator, but if
you're placing things along the path you're doing most of that
computation already, so it's almost no more work. It has an added bonus
of working with any spline type you want.
So for example, you give a spline of:
#declare pathfunction = spline{
linear spline
0, <1,0,0>
20, <0,1,0>
you'll get a chain that starts going in +x and bends to be going +y by
the end of the 20 unit chain, i.e. a quarter circle (a real circle needs
natural_spline, but you get the idea). You have to fiddle with it to get
the right look and figure out where it ends, but that's not too hard.
The follower code:
#local dx = /*distance between centers of chain links*/
#local i = 0;
#local currentposition=<0,0,0>;
union{
   #while (i < Length)
     #local currentdirection=vnormalize(PathFunction(i+0.5));
     #local currentposition=currentposition+dx*currentdirection;
     object{ /* chain segment */
       Reorient_Trans(x,currentdirection)
       translate currentposition}
     #local i = i + 1;
Example render:
http://fc07.deviantart.net/fs22/i/2009/249/4/c/Full_Persian_Fun__CGI__by_cshake.png
