I'm looking for a way to produce a sphere with deep cracks in it, like a broken
marble, or say a moon that got hit hard by something big...?
Any help would be appreciated.
A.D.B.
You can do that with textures but I would recomend to model the whole thing and
then complete the job with a good texture. Try with Wings3D.
> A.D.B.
> > A.D.B.
I'm not entirely certain I know what you mean by "Model the whole thing"... but
I don't have Wings3D, and I really don't use anything but POV. I've tried
creating the object as an Isosurface with cracks made using a crackle pattern,
but the cracks propagate straight through along an axis, rather than down from
the surface.
I think that what I need is a high-definition height map, with the crack drawn
in. Something that I can wrap around a sphere...
At least that way, I'll be able to handle impact craters at the same time.
A.D.B.
I mean to model/sculpt the cracked sphere
Wings3D is a free subdivision modeler very easy to use and tuned to export
models to povray as meshes.
http://www.wings3d.com/
> I've tried creating the object as an Isosurface with cracks made using a crackle
pattern,
> the surface.
this way you can do exactly the object you want and then export it to Pov
you can also wrap a crackle pattern around a sphere
using a spherical warp {}. Then the corresponding pigment
function should be suitable for use in the iso_surface by
subtracting it from the base sphere.
That didn't really work too well, and I tried several variations...
I have to say, I'm rather unimpressed with Wings3d, the controls seem rather
cryptic. I'm not a PoV purist, but I feel all thumbs with modelers...
The more I think about it, the more I feel a height map might be the way to go,
but I have no idea of how to create a height map suitable for a spherical
mapping.
A.D.B.
> mapping.
http://wiki.povray.org/content/Documentation:Reference_Section_7.3#The_HF_Macros
That depends of course on what you want to achieve.
I just gave it a try and came up with the following image:
http://news.povray.org/povray.binaries.images/thread/%3C4ce58bc6%40news.povray.org%3E/
The isosurface definition is given by the code snippet below:
#declare P_WARPED_CRACKLE = pigment
crackle turbulence 0.3 scale 0.04
warp {spherical dist_exp 0}
color_map
[0.00 color rgb 0.00]
[0.06 color rgb 0.85]
[0.30 color rgb 0.95]
#declare f_warped_crackle = function
pigment {P_WARPED_CRACKLE}
#declare f_valleys = function(x,y,z)
f_warped_crackle(x/(f_sphere(x,y,z,1)+1),y/(f_sphere(x,y,z,1)+1),z/(f_sphere(x,y,z,1)+1)).red
#declare f_implicit = function (x,y,z)
f_sphere(x,y,z,1.8+0.2*f_valleys(x,y,z))
isosurface
function { f_implicit(x,y,z) }
contained_by { box { -2,2 } }
accuracy 0.001
max_gradient 10
I forgot to mention the snippet uses f_sphere() so
it requires an #include "functions.inc"
