POV-Ray : Newsgroups : povray.general : Disable the rendering of the unit points in POVRay Server Time
23 Aug 2025 21:56:10 EDT (-0400)
  Disable the rendering of the unit points in POVRay (Message 1 to 5 of 5)
Subject: Disable the rendering of the unit points in POVRay
Date: 6 Oct 2010 08:40:01
Message: <web.4cac6d9226592c8cecfd930f0@news.povray.org>
This is something I could not figure out yet. When I render my scenes in POVRay,
I always get the unit points (0/0/0, 1/0/0, 0/1/0, 0/0/1) rendered using sphere
in color red, green, blue and yellow.
How can I disable this?
Thank you in advance
Subject: Re: Disable the rendering of the unit points in POVRay
Date: 6 Oct 2010 08:48:28
Message: <4cac701c@news.povray.org>
Can you provide a bit more context ?
Are you using povray directly or from a modeler ?
As far as I know, there is no hard-coded spheres in code to do that.
So it must be something upstream the renderer.
Date: 6 Oct 2010 10:46:38
Message: <4cac8bce$1@news.povray.org>
yes ... my thoughts exactly ;-)
could it be transforming an object ... changing colors ... hmmmm
Date: 6 Oct 2010 13:10:48
Message: <4cacad98$1@news.povray.org>
Can you post a small sample scene that display that?
As far as I can tell, if you see things at those location, then they
must be defined to be at those locations in your scene.
Date: 6 Oct 2010 17:00:22
Message: <web.4cace26debf6daa4ecfd930f0@news.povray.org>
> Alain
Thank you guys. I could fix it. It was something that was defined and drawn by
another colleague. I am working on a larger project and I am not aware of the
complete code.
Thank you very much.
