POV-Ray : Newsgroups : povray.general : fog type : "from the back"? Server Time
23 Aug 2025 21:52:56 EDT (-0400)
  fog type : "from the back"? (Message 1 to 10 of 10)
Subject: fog type : "from the back"?
Date: 15 Sep 2010 14:40:01
Message: <web.4c9112ed73fd337522a68e3d0@news.povray.org>
i see fog type 1 and 2 for constant and "from the floor" respectively.
i take that to mean a fog that recedes from the viewer needs some manipulation
of the scene, i.e. so it is flipped 90 degrees using fog_type 2?
-bryan
Subject: Re: fog type : "from the back"?
Date: 15 Sep 2010 15:15:00
Message: <web.4c911af8c6990d6722a68e3d0@news.povray.org>
"CapitalSpace" <bry### [at] gmailcom> wrote:
> some manipulation
i am trying the up vector - seems like this should do it - but looks weird, e.g:
up <0, 0, -1>
or
up <0, 0, 1>
Date: 15 Sep 2010 15:19:20
Message: <4c911c38$1@news.povray.org>
> -bryan
check out:
http://wiki.povray.org/content/Documentation:Reference_Section_3.1#Fog
particular attention to "up" and transformations ... I believe a TDG
used this (see "Morning on the lake" in p.b.i)
Date: 15 Sep 2010 15:45:00
Message: <web.4c9121a7c6990d6722a68e3d0@news.povray.org>
Jim Holsenback <jho### [at] povrayorg> wrote:
> check out:
yes, thanks it appears i have the test pov working with this.
however, my own scene has the camera with "up 39.00*y" - any caveats about
mixing the up vectors? the scene seems ok.
oh, and should fog play nicely with radiosity?
i originally wanted the fog to start from a certain point, so the foreground is
always unaffected by fog : but it seems "that's not how it works".
-bryan
Date: 15 Sep 2010 18:26:01
Message: <4c9147f9$1@news.povray.org>
>> check out:
hmmm ... Don't believe I've ever used anything other than the default
"up" in a camera definition. Perhaps with such a large up vector you
might be having a granularity issue ... that is a little bit of
transformation (rotation) produces too big a change (degrees). If your
setup is something vaguely like: camera in -z looking toward +z then fog
transformation in the x (rotate) might do the trick ... rotate so that
the ground fog is below the ground plane in the foreground.
Should ... if you have any media in containers sometimes the containers
become slightly visible if the fog intercepts
Give the default camera "up" a try and experiment
Date: 15 Sep 2010 20:15:01
Message: <web.4c916028c6990d6722a68e3d0@news.povray.org>
> If your
woo hoo! this did it! i corresponded the up's like this :
camera up 39.00*y
fog up 39.00*z
and i'm a happy camper. FYI the default camera is from molscript.
thanks Jim!
-bryan
Date: 16 Sep 2010 12:55:54
Message: <4c924c1a$1@news.povray.org>
> Jim Holsenback<jho### [at] povrayorg>  wrote:
>> check out:
> -bryan
Fog never interact with radiosity. As fog is not realy a media, adding
media on have no effect. Radiosity can never illuminate any media, and
even less fog. No light source can illuminate a fog ether.
Ground fog never goes to zero density, the density fall off as the
inverse square of the altitude. Any area under fog_offset is constant.
If you want to exclude an area, you need to use a non-hollow plane. If
the camera is inside that plane, you need to diference a sphere from the
plane around the camera so that the camera is not inside a non-hollow
object.
Date: 17 Sep 2010 06:25:00
Message: <web.4c9340f7c6990d67196b08580@news.povray.org>
> camera up 39.00*y
> fog up 39.00*z
> thanks Jim!
Ah, so *that's* how it's done: changing the fog's up vector is the key. (I never
could get such a thing to work by just *rotating* the ground fog. No wonder!)
Re-reading the documentation, I see that the explanation is there, clear as day.
I don't know how I missed that.
Ken
Date: 17 Sep 2010 06:25:01
Message: <web.4c93418fc6990d67196b08580@news.povray.org>
Alain <aze### [at] qwertyorg> wrote:
> ...If you want to exclude an area, you need to use a non-hollow plane. If
> object.
Another clever idea, worth trying. Thanks, Alain.
Ken
Date: 17 Sep 2010 17:24:58
Message: <4c93dcaa$1@news.povray.org>
Am 16.09.2010 18:55, schrieb Alain:
However, the other way round, fog /does/ affect radiosity; the fog will
effectively appear to "illuminate" the scene.
