POV-Ray : Newsgroups : povray.general : fractal pattern help Server Time
23 Aug 2025 01:00:09 EDT (-0400)
  fractal pattern help (Message 1 to 3 of 3)
Subject: fractal pattern help
Date: 3 Aug 2010 15:30:01
Message: <web.4c586d22bb57c5a99e1c416d0@news.povray.org>
I'm looking for a fractal pattern to simulate the veins in a leaf, a function
would do nicely, but I need something that can be rotated around a point.
Something like this:
http://www.easywildflowers.com/quality/ner.lu2.jpg
Any suggestions or ideas would be appreciated.
thanks in advance.
A.D.B.
Subject: Re: fractal pattern help
Date: 4 Aug 2010 01:15:09
Message: <web.4c58f6412a7c91b6f99d05c80@news.povray.org>
I posted a way to use the logistic map as a pattern last year.  Applying a few
warps like the ones below might get you started.
// Persistence of Vision Ray Tracer Scene Description File
// File: lm_pattern.pov
// Vers: 3.6, 3.7
// Desc: Logistic Map Pattern Example
// Date: 20010-08-03
// Auth: David Wagner
// Cite: http://en.wikipedia.org/wiki/Logistic_map
// Returns the distance to the nearest logistic value after lm_imin iterations.
#declare lm_i_distance_min = function( lm_r, lm_pop, lm_val, lm_nearestpop,
lm_i, lm_istart, lm_iend ) {
   select(lm_i > lm_iend, 0,
     lm_i_distance_min(
       lm_r,
       lm_r*lm_pop*(1-lm_pop),
       lm_val,
       select(lm_i > lm_istart & ( (abs(lm_pop-lm_val) <
abs(lm_nearestpop-lm_val)) ),0,
         lm_nearestpop,
         lm_pop),
       lm_i+1, lm_istart, lm_iend ),
     //abs(lm_val-lm_nearestpop) // Includes a straight line along the edge.
     select(lm_nearestpop<(1-0.5/lm_iend),0,1,abs(lm_val-lm_nearestpop) )
     )//end recursion select
// Calls the recursive iterating function.
#declare lm_fn_distance_min = function( lm_r, lm_val, lm_istart, lm_iend ) {
  lm_i_distance_min(lm_r,0.5, lm_val, 1, 1, lm_istart, lm_iend)
#local lm_istart= 20  ;//Minimum iterations.
#local lm_iend  =100  ;//Maximum iterations.
#local n_circum = 25  ;//Number of repeats around the circle.
#local r_offset=   0.0;//Can make a rosette in the center.  Try 0.01 or larger.
cylinder{<0,0,0>,y*0.1, r_offset+4
  texture{
      function { lm_fn_distance_min(z,x, lm_istart, lm_iend) }
      poly_wave 0.25
      color_map{[0 0.25*Green][1 LimeGreen]}
      warp{ repeat x flip x} //circumferential
      warp{ repeat z*4 }     //radial
      warp{turbulence 0.1*(x+y)}
      translate z*r_offset
      scale 0.5/ n_circum *(x) +y+z
      warp{ cylindrical orientation z dist_exp 0 }
      warp{ black_hole <0,0,0>, 4 inverse falloff 0.5}
      }//end pigment
  }//end texture
  location  <0,6,-9>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
sky_sphere {
    gradient y
    color_map {
      [0.0 rgb <0.6,0.7,1.0>]
      [0.7 rgb <0.0,0.1,0.8>]
light_source {<0, 0, 0>
  color rgb <1, 1, 1>
  translate <-30, 30, -30>
Date: 4 Aug 2010 10:20:00
Message: <web.4c5976c82a7c91b6f99d05c80@news.povray.org>
I forgot to include the following warnings.  Please put this near the top of the
code posted.
// WARNING: Declare this function first in a scene.
// WARNING: This recursive function is invalid SDL and can crash POV-Ray.
It would be a good idea to move the #include "colors.inc" line to after the
function declarations, as well.
