POV-Ray : Newsgroups : povray.general : how to visualize what you want? Server Time
23 Aug 2025 03:09:32 EDT (-0400)
  how to visualize what you want? (Message 1 to 10 of 22)
Subject: how to visualize what you want?
Date: 17 Jul 2010 03:50:00
Message: <web.4c415fa19a99249a516ec1d10@news.povray.org>
I used POV ten or fifteen years ago and it was a Windows-based GUI system. I
have long since forgotten everything that I knew, and I have moved on to Linux.
Since there aren't many, if any, GUI modeling programs for Linux, I was looking
at the tutorials on writing the code in a text editor. While I am perfectly
capable of writing code using a text editor in numerous BASIC, C++, PHP and HTML
languages, that's more of an abstract process.
What I am curious about is hard to explain. I guess... how do you 'see' what you
are designing when you are only working with code. How do you know that the
camera goes here. How do you that this shape is at these coordinates. I guess I
am having a hard time understanding how you plot an image that you can't see.
I hope what I am asking makes sense. I'm not asking for a tutorial on how to
write the code. More of the mentality behind writing the code. Or maybe I am
missing something?
Thanks for your patience in reading this (since you got this far :)
Subject: Re: how to visualize what you want?
Date: 17 Jul 2010 04:10:32
Message: <4c416577@news.povray.org>
  You visualize the space in your head, and you make lots of test renders.
Perhaps not the most efficient process in existence, but it's workable.
(Besides, it trains your spatial recognition skills, which is always a plus.)
Date: 17 Jul 2010 05:44:18
Message: <4c417b72$1@news.povray.org>
You might find it useful (I do) to create a crude grid out of cylinders
... something that marks <0,0,0> and each of the directions x,y,z
positive and negative (color coded) with some sort of tic mark(s), say
every 5 units ... save it as an include file then conditionally include
when you need it :-)
Jim
Date: 17 Jul 2010 07:00:00
Message: <web.4c418c41f4e69ab44f28787e0@news.povray.org>
What Warp said.
It basically boils down to experience I think - you run test renders, and
eventually you just end up needing fewer test renders. I think many of the
posters here have used POV (as you did) long before gui-based modellers became
common (and/or free), and it's just practice. Of course there are things you can
do to aid the process, as Jim suggested. You might find some old ways of
thinking come back to you quicker than you expect!
Date: 17 Jul 2010 11:23:02
Message: <4c41cad6$1@news.povray.org>
news:web.4c418c41f4e69ab44f28787e0@news.povray.org...
> What Warp said.
> became
> you can
And in addition, just the old pencil and paper. I use a lot of that too,
from arithmetics to sketches.
Date: 17 Jul 2010 12:57:08
Message: <4c41e0e4$1@news.povray.org>
Blender and wings3d are two that come immediately to mind.
Jim
Date: 17 Jul 2010 17:30:42
Message: <4c422102$1@news.povray.org>
> Jim
I use Wings3d quite a bit to set primitives around the scene and give
them descriptive names. After the .pov and .inc files are exported, I
can go back and hand edit the files and insert or modify the objects I
want. Wings will handle a lot of primitives as well as more complex
objects by default, converting them to mesh2 objects in an .inc file.
However, Wings3D won't to CSG operations or more complex objects like
quartics.
So, since Wings3d won't do a quartic object, I'll place a cylinder
somewhere in the scene and name it "quartic_1" or similar. Then I can
edit the exported files, find "quartic_1" and work in the code I wish to
have there.
It sounds a bit complicated, but actually, once you get your scene set
up, it goes fairly quickly. YMMV.
Cheers.
Date: 18 Jul 2010 00:40:00
Message: <web.4c4284b1f4e69ab4516ec1d10@news.povray.org>
I was thinking maybe pencil and graph paper like Thomas suggested.
jim mentioned Blender for Linux. I tried Blender a couple of months ago when I
needed a CAD program for the new CNC machine I built and I could not make heads
or tails out of it. I do like Sketchup and I saw a post here about a SU2POV
plugin. I think I may give that a try and see how it works.
I really appreciate all of the advice and comments...
Date: 18 Jul 2010 04:42:14
Message: <4c42be66$1@news.povray.org>
"rebeltaz" <mrm### [at] bellsouthnet> schreef in bericht
news:web.4c4284b1f4e69ab4516ec1d10@news.povray.org...
And don't forget Warp's suggestion. Mental visualization, even the most
complex ones, comes first, often even before paper and pencil.
Date: 31 Jul 2010 11:07:45
Message: <4c543c41@news.povray.org>
> missing something?
A small idiosyncratic note related to positioning the camera.  I try to
leave the main focus of my scene at the origin or maybe directly above
the origin. So I point the camera there.  I then position the camera,
and sometimes the lights too, utilizing the vrotate command.  Personally
I have found this a more intuitive way to control the distance and angle
of the camera to a subject.
e. g.
   location  vrotate ( <0,0,-10>, <20,30,0> )
   look_at   <0.0, 0.0, 0.0>
This would place the camera at 10 units distance along the -z axis then
rotate it around the subject, upward 20 degrees, then to the left 30
degrees.
It is not for every situation, of course. Sometimes you know you want to
locate the camera 'over behind the couch' or 'at the eye height of a
figure in the doorway' and have it look at 'the center of the table',
and so you do that with simple vectors like all the other objects.
