POV-Ray : Newsgroups : povray.general : asymmetric density maps Server Time
23 Aug 2025 00:58:13 EDT (-0400)
  asymmetric density maps (Message 1 to 10 of 13)
Subject: asymmetric density maps
Date: 13 Jul 2010 15:30:01
Message: <web.4c3cbdb2a2a99b937b60f60@news.povray.org>
Hello,
is there a way to create asymmetric density maps?
As I understand it, you can have a spherical, cylindrical or boxed density
distribution (as the "normal" ones) where the distribution is defined with
respect to the center:
for example
  density{ cylindrical
    turbulence 0
    color_map {
     [0 rgb 0.0]//border   <===
     [1 rgb 1.0]//center   <===
But how would I "move" the area of higher density to a spot next to the center
of my object?
Thanks for any ideas and hints.
Subject: Re: asymmetric density maps
Date: 13 Jul 2010 18:03:50
Message: <4c3ce2c6@news.povray.org>
yes, how to do this depends on what you mean by asymmetric.
> density distribution (as the "normal" ones) where the distribution is
> defined with respect to the center:
actually its defined with respect to the origin <0,0,0>,
not the to the center of any particular object. Note that
translating an object *after* applying the density to its
interior will also move the attached density.
> the center of my object?
Either create the original geometry off-center (e.g.,
sphere {<a,b,c>,1>}) or translate the density itself
(e.g. density {cylindrical ... translate <a,b,c>}).
This way the density will still be symmetrical, just
not with respect to the center of your object.
Date: 14 Jul 2010 08:20:00
Message: <web.4c3dab0265b32c57937b60f60@news.povray.org>
Thanks for the answer.
Unfortunately, I was looking for an asymmetric density distribution.
But maybe, I could try something with the translation of the density.
Date: 14 Jul 2010 10:15:01
Message: <web.4c3dc5fb65b32c576bb935490@news.povray.org>
Densities are not restricted to spherical, cylindrical and boxed! There are a
lot of other built in patterns and on top of that you can define your very own
density functions!
Date: 15 Jul 2010 17:07:16
Message: <4c3f7884@news.povray.org>
> Hello,
> for example
>      turbulence 0
>      color_map {
>       [0 rgb 0.0]//border<===
>       [1 rgb 1.0]//center<===
> of my object?
A few possibilities:
  - Create your object around the origin, then, rotate and translate it
to the desired location. This should be the method of choice.
  - Rotate/translate the density to place it into your object as you like.
You can also stretch/compress the pattern using scale. To it BEFORE you
place it in it's final location as the transformation will cause the
pattern to move if it's not at the origin.
You can rotate the pattern as needed. Must also be done to the pattern
at the origin, otherwise it will orbit around the origin.
Remember: ALL scale and rotate are ALWAYS done relative to the origin
(point <0,0,0>).
You can also use about any user defined function or any of the other
predifined patterns.
Date: 31 Jul 2010 11:57:38
Message: <4c5447f2$1@news.povray.org>
McMinty wrote:
> Hello,
> for example
>     turbulence 0
>     color_map {
> of my object?
try black_hole warp?
not sure if it would parse but worth a try
Date: 31 Jul 2010 15:38:05
Message: <4c547b9d$1@news.povray.org>
   location  <0,0,-10>
   look_at   <0.0, 0.0,  0.0>
   angle 20
// create a regular point light source
light_source {
   0*x                  // light's position (translated below)
   color rgb <1,1,1>    // light's color
   translate vrotate(<0,0,-100>,<60,60,0>)
sphere { 0, 1
   hollow
   material{
     texture{
       finish{
         ambient 0
         diffuse 1
         specular 0
         reflection 0
       pigment {rgbt  .99}
     interior{
       media {
         intervals 1
         samples 1,5
         emission 1
         method 3
         density{
           spherical
           warp{black_hole <2,0,0>,2}
           warp{black_hole <0,2,0>,2}
           color_map{
             [.25 rgb 0]
             [1 rgb y]
Date: 31 Jul 2010 17:33:16
Message: <4c54969c$1@news.povray.org>
> camera {
> location <0,0,-10>
> angle 20
> light_source {
> sphere { 0, 1
> hollow
> material{
> texture{
> finish{
> ambient 0
> diffuse 1
> specular 0
> reflection 0
> pigment {rgbt .99}
> interior{
> media {
> intervals 1
> samples 1,5
> emission 1
> method 3
> density{
> spherical
> color_map{
> [.25 rgb 0]
> [1 rgb y]
The black_hole allows you to create a local perturbation in the pattern.
It don't allow you to translate the pattern.
Here, you pull the media into a non-spherical shape.
What was asked was how to place the media pattern relative to an object
that is NOT defined around the origin.
In your sample, how to place correctly the spherical pattern if the
sphere is defined as:
sphere{<125, 55, 73>, 1... instead of sphere{0,1...
Also, your sampling is way wrong.
Method 3 is the default. It needs at LEAST samples 3 and default to
samples 10.
samples 1,5 realy mean samples 1
The second value is always ignored.
Lastly, your light is useless in that particular scene.
Date: 31 Jul 2010 18:31:44
Message: <4c54a450@news.povray.org>
Alain wrote:
>> camera {
>> location <0,0,-10>
>> angle 20
>> light_source {
>> sphere { 0, 1
>> hollow
>> material{
>> texture{
>> finish{
>> ambient 0
>> diffuse 1
>> specular 0
>> reflection 0
>> pigment {rgbt .99}
>> interior{
>> media {
>> intervals 1
>> samples 1,5
>> emission 1
>> method 3
>> density{
>> spherical
>> color_map{
>> [.25 rgb 0]
>> [1 rgb y]
> samples 10.
> Alain
No, he asked how to make the pattern asymmetrical. Black_hole is hardly
a general way, or even particularly good way to do it, but it is a crude
way to stretch a pattern arbitrarily and might suffice depending on the
problem being addressed. Sometimes one idea leads to another.
I think you are applying your own quite limited meaning to the word
'asymmetrical'
The scene that I provided was what I used to test if the warp would
parse in a density statement.  I just gave a example scene that could be
rendered to show the effect of the warp.  The light was used to dimly
illuminate the containing media sphere. Sure, there are other ways to do it.
Date: 1 Aug 2010 03:35:25
Message: <4c5523bd$1@news.povray.org>
Yes, this works nicely indeed. I had been thinking about this issue a few
weeks ago and decided then that warp{turbulence} was giving enough assymetry
to the media to satisfy me. However, black_hole is giving me new ideas to
explore.
Thanks, Jim!
