I have a complicated deformed mesh. Is there documentation on how to texture it
with an image? (It is a "topological" rectangle that looks like a hanging table
cloth.)
Many thanks in advance,
Sam
Am 28.06.2010 21:46, schrieb Sam Takoy:
> cloth.)
"UV mapping" is what you'll want to have a look at. You'll have to
assign 2D coordinates (termed U and V) to the vertices of each triangle
in the mesh, thereby specifying the triangle's position in 2D "image space".
> > cloth.)
Thank you.
It seems that if I only have a single triangle in a mesh, it will sample three
points from the image and interpolate from those three values. Rather than keep
looking at the pixels in the image and place those pixels in the right place in
the triangle. Am I correct? (I hope not.)
> > > cloth.)
> Thank you.
As a follow up, here is he image:
http://freeboundaries.com/Equations.png
and here is the pov ray result
http://freeboundaries.com/pov.png
Thank you very much in advance.
You are incorrect. It interpolates the (u,v) coordinates, and samples
the image separately for each pixel on the triangle.
- Slime
