Am 03.06.2010 10:37, schrieb DH0909:
> I want the names of the single frames to be set according to some text that is
> used in the different frames. (I use the animation to run through an array with
> strings.)
> I don'T want to name some hundred picture files manually after the rendering.
> (After all this is a hobby for me. =)
> Can I set the OutputFileName somehow so it reflects the strings from the array?
> Maybe by pasting the array somehow in the ini-file?
> Or do I really have to generate a seperate ini-file for every frame with another
> program first?
There is no way to change the OutputFileName from the SDL code.
What you can do, however, is have the SDL code create a batch file or
shell/Perl/Tcl/Whatever script (using the #fopen and #write statements),
which you can then run after the renders to automatically perform the
renaming.
