hi to all, i'm a newbie on povray an i have a little problem:
i write a sky with this code:
sky_sphere{
pigment{
image_map{ jpeg "sky.jpg"
map_type 2 // cylindrical
interpolate 2 // bilinear
once //
} // end of image_map
scale<1,1.02,1> rotate<0,0.00,0>
} // end of sky_sphere --------------------
but with this code, the color blue of the sky is in all object in my
scene...that is, in the object of the scene there is a blue component.
How i can do, for delete this effect?
thanks in advance!
Am 04.05.2010 12:06, schrieb angel3435:
> sky_sphere{
> pigment{
> once //
To answer that question, we'd need to know how you /achieved/ that
effect in the first place. It's not like that's normally automatic with
the quoted code.
Are you perhaps using radiosity? That would indeed effectively turn the
sky sphere into a diffuse blue illumination source - which, if you think
about it, is perfectly realistic. Note though that in reality, the
primary direct illumination source - the sun - has a somewhat yellowish
hue, which on average cancels out this effect.
> the quoted code.
Yes, i'm using radiosity. The sun is my only light source and has a white color?
I must change his color to a yellowish one?
Am 04.05.2010 12:51, schrieb angel3435:
Is that a question, or rather a statement with a typo question mark? I
guess you should know yourself what light sources are in your scene.
Yes - if you want a more neutral overall colouring of your image, you'll
need to do that.
> need to do that.
Excuse me, in the first question there is a wrong question mark! sorry!
