Quite impressive. I just bought an Athlon II x4 (thank you AMD for maintaining
backwards compatibility!) and wanted to see how fast thing thing was. One
interesting test I did was to render a particular scene using 3.6 with 4
instances vs. 3.7. I was expecting the render times to be about the same. Yet,
3.7 took half the time that 4 instances of 3.6 did. What's allowing this speed
up?
Also, it might be time to assemble a 16-core computer with
2 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819105266&cm_re=magny-cours-_-19-105-266-_-Product
1 of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813151212&cm_re=socket_g34-_-13-151-212-_-Product
and gobs of RAM...
> up?
if it's a scene with radiosity, clipka contributed a lot of high-caliber
optimizations and cleanups for this feature.
> up?
With 4 instances of 3.6, it takes 4 times as much memory. You may start
swaping. You need to parse 4 times, and only once with 3.7.
With 3.7, data collected by a core can be reused by the others, that's
impossible in 3.6 and multiple instances.
> > up?
No radiosity in the scene. Also, definitely no swapping since I have 4GB and the
scene only uses 200MB max. I thought it might be memory issues, but I then
compared the test scene on 3.6 running one instance vs. running 4 instances and
they all finished at the same time.
> > > up?
for a fair comparison, each instance of 3.6 should be rendering 1 corner of the
image divided by 4. It's roughly what 3.7 does automatically (to as many cores
as you have).
> up?
Did you try with the non-SSE2 version of 3.7?
> > up?
Custom compiles for 3.6 and 3.7 on Debian 5.0 x86-64 (gcc 4.3), so I would
assume they're both SSE2 enabled.
I think I found the problem. Back when I was using the old processor, I compiled
3.6 with -march=k8. But when I switched processors I didn't think to recompile.
After recompiling with -march=barcelona, I got a 40% speed increase with 3.6!
The configure script for 3.7 uses -march=native so I think that might account
for why it seemed to be so much faster.
