POV-Ray : Newsgroups : povray.general : Square Root problem Server Time
5 Mar 2026 11:09:09 EST (-0500)
  Square Root problem (Message 1 to 9 of 9)
Subject: Square Root problem
Date: 14 Mar 2010 10:40:01
Message: <web.4b9cf50c3ef55f81da0e3b8d0@news.povray.org>
The following problem:
From a triangle from whom i know the length of both legs (A and B) i want to
calculate the longest leg (C).
As i remember from school its C*C=A*A+B*B where A=62.5 and B=17.
Translated into PovRay its C=sqrt(pow(A,2)+pow(B,2)) but the result is much
smaller. The correct result for C should be +/-32.596
Code:
#local RH=149;  // Rail Height
#local FW=125;  // Flange Width
#local HT=65.4; // Head Width at Top
#local HB=70;   // Head Width at Base
#local HH=39.8; // Head Height
#local WT=14;   // Web Thickness
#local FE=10.5; // Flange Thickness at Edge
#local FM=27.5; // Flange Thickness at Center
#local Y_X=76;  // Gravity Center
#local FMT=degrees(atan((FM-FE)/(FW/2)));
//c = sqrt( pow( a , 2) + pow( b , 2 ) ) .
#local FE_FM=sqrt(pow((FM-FE),2)+pow(FE/2,2));
box{<0,FM,0><FE_FM,0,1> Rotate_Around_Trans(<0,0,-FMT><0,FM,0>) pigment {Red}}
End Code
But maybe there is a error in the box code becourse is i replace FE_FM with that
value is displayed wrong also.
Regards
Harry
Subject: Re: Square Root problem
Date: 14 Mar 2010 12:57:24
Message: <4b9d1574$1@news.povray.org>
14.03.2010 18:39, gharryh пишет:
it works only if angle between A and B is equal 90 degrees, in other
case use e.g. theorem of sinus
A/sin(alpha) = B/sin(beta) = C/sin(gamma)
> Code:
> End Code
> Regards
> Harry
Date: 14 Mar 2010 15:26:06
Message: <4b9d384e$1@news.povray.org>
14.03.2010 20:57, slair пишет:
>> want to
>> much
http://en.wikipedia.org/wiki/Law_of_sines
>> Code:
>> pigment {Red}}
>> End Code
>> with that
>> Regards
>> Harry
Date: 16 Mar 2010 08:15:19
Message: <4b9f7657$1@news.povray.org>
I don't know where you get your C=32.596 from but this is impossible, in
this case A would be bigger than B+C, which means that no triangle will
have sides of these lengths, no matter what the angles are...
Vincent
Date: 16 Mar 2010 16:29:41
Message: <4b9fea35@news.povray.org>
Le 2010-03-16 08:15, Vincent Le Chevalier a écrit :
>> want to
>> much
It can be possible, but definetly not in plane geometry.
If you trace your triangle on a curved surface, and the triangle is
large relative to the curvature of said surface, the sum of the angles
can get larger than 360 degrees, close to 539.999 degrees can become
possible, and the relative length of the sides amount to any relations.
Trace a very large triangle around the Earth, 2 sumits on the equator
and the third one 1mm away from it, located at longitudes 0, 120 and
-120, and mesure the angles on the ground.
Date: 16 Mar 2010 16:54:07
Message: <4b9fefef$1@news.povray.org>
Well it's not possible either in spherical geometry, and I doubt you'll
find a "reasonable" space that does not respect triangle inequality...
Remember, my argument was not about the angles but about the distances.
What I'm saying is that if you're looking for a triangle where the
length of one side is longer than the sum of the lengths of the other
two sides, you have bigger problems than the square root to worry about...
Vincent
Date: 16 Mar 2010 17:28:28
Message: <4b9ff7fc@news.povray.org>
	Actually, it is possible in spherical geometry. You just have to
remember that two points are not sufficient to define an edge on a
sphere: there are two possibilities, one of which goes around the
sphere...
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Download 'us-ascii' (1 KB)
Date: 16 Mar 2010 17:58:48
Message: <4b9fff18$1@news.povray.org>
> sphere...
Ah yes, I was thinking of the triangles specified by joining the points
according to the great-circle distance, i.e. the shortest arc between
the vertices.
Problem is that if you allow to build triangles using the other arcs
(the ones that go all the way around), you end up also allowing
triangles that have intersecting sides, which is interesting, I guess,
but then calling them triangles is perhaps slightly abusive :-)
Vincent
Date: 19 Mar 2010 10:45:01
Message: <web.4ba38d3071cdd7cfda0e3b8d0@news.povray.org>
> > sphere...
> the vertices.
> Vincent
Problem is solved using this:
#macro flange() // Create the bottom flange
difference {
        union {
                box{<0,FM,0><FE_FM,0,1> Rotate_Around_Trans(<0,0,-FMT><0,FM,0>)}
                box{<0,FM,0><-65,0,1> Rotate_Around_Trans(<0,0,FMT><0,FM,0>)}
                box{<-FW/2,0,0><FW/2,FE,1>}
        box{<-FW/2,0,-0.1><FW/2,-FE*1.75,1.1>}
Harry
