POV-Ray : Newsgroups : povray.general : Suspected bug: difference of isosurfaces invisible Server Time
5 Mar 2026 11:09:08 EST (-0500)
  Suspected bug: difference of isosurfaces invisible (Message 1 to 4 of 4)
Subject: Suspected bug: difference of isosurfaces invisible
Date: 5 Mar 2010 01:00:08
Message: <web.4b909cbe38c6c974fa8cd9d70@news.povray.org>
Subtracting two isosurfaces to create a shell, portions of the shell where the
inner (subtracted) surface should be visible are completely transparent.  Some
shadows are cast by the invisible shell.  Other shapes I've tried do not do
this.
I've tried this on Linux (Kubuntu 9.10 fully patched, POV-ray 3.6.1 as compiled
by Debian) and Windows Vista (32-bit fully patched, POV-ray 3.6.2 and
3.7.beta.35a) on a P4 dual core 3GHz, 3GB RAM computer, and on WinXP Home
(POV-ray 3.6.2 and 3.7.beta.35a, Core 2 Duo 2.33GHz, 1GB RAM, Japanese).
Sample code:
background { color <0,0.1,0.2> }
  orthographic
  location <2, 6, -20>
  right <8, 0, 0>
  up <0, 6, 0>
  look_at <0, 0, 0>
light_source { <50, 50, -20> colour <1,1,1> }
light_source { <-20, -5, -10> colour <1,1,1> }
light_source { <-2, 5, -10> colour <1,1,1> }
difference{
isosurface{
    function{ pow(x,2) + pow(y,2) + pow(z,2) - pow(2.5,2) }
    contained_by { sphere { <0,0,0>, 2.51 } }
    max_gradient 5.1
    pigment{color <1,1,0>}
isosurface{
    function{ pow(x,2) + pow(y,2) + pow(z,2) - pow(2.4,2) }
    max_gradient 5.1
  box { <0, -5, 0>, <5, 5, -5>
    rotate <0, 45, 0>
    pigment{ color <1,1,0> }
// I found the following helpful in demonstrating the issue
difference{
 torus{ 1, 0.2
      pigment{ color <1,0,0> }
      translate <0,-2.35,0>
    rotate <0, 45, 0>
Subject: Re: Suspected bug: difference of isosurfaces invisible
Date: 5 Mar 2010 04:54:07
Message: <4b90d4bf$1@news.povray.org>
> this.
You need to use all_intersections if you want to use isosurfaces like this
in CSG. This is explained in the document section about isosurfaces, see
<http://www.povray.org/documentation/view/3.6.1/300/>.
	Thorsten, POV-Team
Date: 5 Mar 2010 07:00:01
Message: <web.4b90f14ddbece785bc32e3c0@news.povray.org>
Thanks!
Well, that's somewhat embarrassing.  I skimmed over that option because I'm
thinking in terms of objects rather than rays, and didn't see a problem with the
intersections of objects.
Date: 7 Mar 2010 09:10:00
Message: <web.4b93b30fdbece78960a564c0@news.povray.org>
> this.
> Sample code:
> camera {
>   orthographic
>   right <8, 0, 0>
>   up <0, 6, 0>
>   look_at <0, 0, 0>
> difference{
> isosurface{
>     max_gradient 5.1
> isosurface{
>     max_gradient 5.1
>     rotate <0, 45, 0>
> difference{
>  torus{ 1, 0.2
>     rotate <0, 45, 0>
tanx...
its amazing information
