POV-Ray : Newsgroups : povray.general : Transparency problem with rolled up plane Server Time
17 May 2025 20:10:46 EDT (-0400)
  Transparency problem with rolled up plane (Message 1 to 4 of 4)
Subject: Transparency problem with rolled up plane
Date: 11 Jan 2010 11:40:01
Message: <web.4b4b533fd9ffef9c75345adc0@news.povray.org>
Hello,
I've a transparency problem with a rolled up plane, which I created by lots of
very narrow boxes:
#declare tube = merge{
                      box {<0,0,0>, <0.2,7.5,0.075> pigment {rgb<0,0,1>}}
                      box {<0.2,0>, <0.366,7.5,0.075> pigment
{rgb<0.2,0.2,0.3>}}
   #declare i = 0;
   #while ( i <= 2000)
      object {tube translate<2.3+i/2500,0,0> rotate <0,i/909*360,0>}
       declare i = i + 1;
Adding a factor of transparency by "transmit" in "pigment" doesn't work. Even if
I add a transmit factor of 0.9 the rolled up plane stays as it is with a factor
of 0.0
What's the reason for the behaviour of this object?
Subject: Re: Transparency problem with rolled up plane
Date: 11 Jan 2010 17:13:07
Message: <4b4ba273$1@news.povray.org>
The object definition looks rather strange: A box is about 0.2 units
wide in x direction, but the spacing you use is about 0.0004 so you
have an overlap of about 500 layers at each surface point. You can't
actually look through that anyway even if you set max_trace_level to
the maximum value of 255.
Date: 11 Jan 2010 20:48:53
Message: <4b4bd505$1@news.povray.org>
> Hello,
> very narrow boxes:
>                        box {<0,0,0>,<0.2,7.5,0.075>  pigment {rgb<0,0,1>}}
>                        box {<0.2,0>,<0.366,7.5,0.075>  pigment
> {rgb<0.2,0.2,0.3>}}
>     #declare i = 0;
>     #while ( i<= 2000)
>        object {tube translate<2.3+i/2500,0,0>  rotate<0,i/909*360,0>}
>         declare i = i + 1;
>     #end
> of 0.0
Your "Tube" object been a merge (or union) of textured objects, any
texture given to the final object would be ignored. Remove the texture
from that part, or have them transparent.
You probably have a max_trace_level problem.
If you wrap your loop in a merge, you may get closer to what you want as
the inside surfaces will get removed.
It will be prety long to render such a merge.
                       box {<0,0,0>, <0.201,7.5,0.075> pigment {rgb<0,0,1>}}
// the 0.201 is to prevent coincident surfaces between the two //components.
{rgb<0.2,0.2,0.3>}}
merge{// this remover the inner surfaces.
    #declare i = 0;
    #while ( i <= 2000)
        declare i = i + 2;
You may need to increase the max_trace_level like:
global_settings{max_trace_leve 20}
You may try using a blob object with many cylinder components like:
blob{threshold 0.1
   #declare i = 0;
   #while ( i <= 2000)
     cylinder{0, <0, 7.5, 0.075>, 0.1, 0.3
         translate<2.0+i/250,0,0>
         rotate <0,i/909*380,0>
   #declare i = i + 1;
   pigment{rgbf<1, 0.3, 0.7, 0.9>}
   rotate <-120, 25, 0>
Date: 21 Jan 2010 10:50:00
Message: <web.4b58767da634737459cfaddb0@news.povray.org>
> very narrow boxes:
I like triangles :-)
As a proof of concept, I threw together a quick example. Please excuse the crude
coding and stupid variable names. Also, it's not a closed mesh, so interior will
not work properly. And some/all of the triangles may be inside out, so making
smooth triangles may need some work.
Enjoy!
-Peter
camera{
        location <5,15,-15> look_at y*3
light_source{<5,15,-15>1}
#local Start_Point = 5; // Loop starts on this x-axis and goes towards zero.
#local Thickness = 0.5; // Thickness of the loops
#local SPC = 0.005; // Space between triangles, decrease for more detail (and/or
use smooth triangles)
#local H = y*5; // Height
#local Safety_Measure = 0.001; // For avoiding coincident surfaces
#local Number_Of_Loops = 2; // Increase for more loops
union{ // White loop
#local X = 0;
#while (X<Number_Of_Loops+1) // One more white than blue loop
#local X2 = X+SPC;
        #local P1 = vrotate(<Start_Point          -   X*Thickness*2,0,0>,y*
X*360);
        #local P2 = vrotate(<Start_Point
-(X2)*Thickness*2,0,0>,y*(X2)*360);
        #local P3 = vrotate(<Start_Point-Thickness- (X)*Thickness*2,0,0>,y*
X*360);
        #local P4 =
vrotate(<Start_Point-Thickness-(X2)*Thickness*2,0,0>,y*(X2)*360);
        triangle{P1  ,P2  ,P3  } // Bottom
        triangle{P2  ,P4  ,P3  }
        triangle{P1+H,P2+H,P3+H} // Top
        triangle{P2+H,P4+H,P3+H}
        triangle{P1  ,P1+H,P2  } // Outer
        triangle{P1+H,P2  ,P2+H}
        triangle{P3  ,P3+H,P4  } // Inner
        triangle{P3+H,P4  ,P4+H}
#local X = X+SPC;
pigment {rgb 1 transmit 0.7}
union{ // Blue Loop
#local X = 0;
#while (X<Number_Of_Loops)
#local X2 = X+SPC;
        #local P1 = vrotate(<Start_Point-Thickness  -Safety_Measure-
X*Thickness*2,0,0>,y*   X*360);
        #local P2 = vrotate(<Start_Point-Thickness
-Safety_Measure-(X2)*Thickness*2,0,0>,y*(X2)*360);
        #local P3 = vrotate(<Start_Point-Thickness*2+Safety_Measure-
(X)*Thickness*2,0,0>,y*   X*360);
        #local P4 =
vrotate(<Start_Point-Thickness*2+Safety_Measure-(X2)*Thickness*2,0,0>,y*(X2)*360);
#local X = X+SPC;
pigment {rgb z transmit 0.6}
