POV-Ray : Newsgroups : povray.general : Merging of Two Boxes Behaviour Server Time
23 Aug 2025 18:53:52 EDT (-0400)
  Merging of Two Boxes Behaviour (Message 1 to 4 of 4)
Subject: Merging of Two Boxes Behaviour
Date: 24 Jul 2009 16:10:00
Message: <web.4a6a14eac8c647532a18a90c0@news.povray.org>
I am new to POV-Ray.  In the example below, I am trying to merge two boxes
together.  But when I render the image, the boxes disappear at the sections
where they intersect.  Is this correct?
How do I get my two boxes to merge into one uniform 'T' shape.  This does not
happen with a 'union'.  But I can't use 'union' because I want to render the
'T' as a 'glass like' object.  Any suggestions?
#include "textures.inc"
global_settings
        max_trace_level 10
        ambient_light White
background { color Gray }
camera
        location <0, 153, -320>
        look_at <0, 153, 0>
merge
        box{<0,233,0>, <233-16,197,36>}
        box{<197,/*233-16*/300,0>, <233,107,36>}
        // Tinted blue crystal
        pigment { rgbf<0.8,0.8,1,0.9> }
        material { M_Glass3 }
        interior { Glass_Interior }
        finish { Glass_Finish }
        translate <-143,10,-18>
        rotate <0,clock,0>
Subject: Re: Merging of Two Boxes Behaviour
Date: 24 Jul 2009 16:20:00
Message: <web.4a6a1706dc7e8ec46e32850e0@news.povray.org>
POV-Ray is a bit weak when dealing with coincident surfaces.
Try translating one of the boxes by a very tiny amount, e.g.
    merge
        box{<197,/*233-16*/300,0>, <233,107,36> translate <0,0,0.001>}
Date: 25 Jul 2009 15:58:54
Message: <4a6b63fe$1@news.povray.org>
> global_settings
>         max_trace_level 10
>         ambient_light White
> camera
>         look_at <0, 153, 0>
> merge
>         rotate <0,clock,0>
You have surfaces that are at exactly the same location. When you
encounter such a case, you can't tell whitch surface to use. In your
case, you end up missing both most of the time, with some pixels that
catch one or the other.
The solution from clipka is one that you can reliably use (you can use a
much smaller value, like 0.00000001). Another way would be to scale one
of the component by something like 0.999999 or 1.000001 along the z axis.
Date: 26 Jul 2009 03:19:36
Message: <4a6c0388$1@news.povray.org>
this should also work:
difference{
        box{<0,107,0>,<233,300,36> }
        box{<-100,233,-100>,<197,500,100>}
        box{<-100,  0,-100>,<197,197,100>}
        rotate <0,clock,0>
> global_settings
>         max_trace_level 10
>         ambient_light White
> camera
>         look_at <0, 153, 0>
> merge
>         rotate <0,clock,0>
