POV-Ray : Newsgroups : povray.general : Smooth Edged Spherical Pattern? Server Time
22 May 2025 05:30:20 EDT (-0400)
  Smooth Edged Spherical Pattern? (Message 1 to 6 of 6)
Subject: Smooth Edged Spherical Pattern?
Date: 9 Jul 2009 14:55:00
Message: <web.4a563c89276d72802f67618b0@news.povray.org>
Hey guys, I'm looking for a function or pigment function that creates a single
bump when added to an isosurface.  I've been tinkering with the spherical
pigment but of course that adds or subtracts a full hemisphere of a sphere onto
the surface.  Is there a way to modify this pigment or is there another function
that creates a more bump like feature where the protrusion smoothly blends into
the underlying surface?  I'd like a single occurence of the pattern because I'd
like to control the placement of it, and I've been trying to avoid multiplying
sphere functions together to create a blob like effect because it kills the
rendering time and alters my surface in too many ways.  Any suggestions would
be appreciated.
Skip
Subject: Re: Smooth Edged Spherical Pattern?
Date: 9 Jul 2009 14:58:39
Message: <4a563dde@news.povray.org>
> be appreciated.
  From 1-dimensional functions the most typical "single smooth bump"
function is f(x) = exp(-x*x). Try plotting that with any function plotter
to see it in action.
  I'm certain the same concept can be extended to 3-dimensional functions.
I guess, although I can't be sure, that f(x,y,z) = exp(-x*x-y*y-z*z) might
do the trick. However, without testing I can't know.
Date: 9 Jul 2009 18:36:05
Message: <4a5670d5$1@news.povray.org>
> be appreciated.
> Skip
With the spherical pattern, you can change the wave type used.
You can try any of those:
sine_wave
cubic_wave
poly_wave
Date: 10 Jul 2009 23:13:51
Message: <4a58036f$1@news.povray.org>
Thanks for the replies...
Alain, I had tried the sine_wave, but I should have carried through and
tried the others.  I got a nice result with the poly_wave and I think
I'm going to keep that one.
Warp, I also tried your function and couldn't get it to show up.  After
getting a nice result with Alain's function I'm not going to dig too
deeply into the math trying to get that function to work, but thanks.
Skip
Date: 11 Jul 2009 08:23:01
Message: <4a588425$1@news.povray.org>
Try this:
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.6;
isosurface {
   function { y - exp(-(x*x + y*y + z*z)) }
//  function { y + exp(-(x*x + y*y + z*z)) }
//  function { y - exp(-(x*x + z*z)) }
//  function { y + exp(-(x*x + z*z)) }
//  function { y - exp(-z*z) }
//  function { y + exp(-z*z) }
   contained_by { box { -<100, 1.1, 100>, <100, 1.1, 100> } }
   pigment { color White }
light_source {
   <1, 3, 2>*100
   colour White
   shadowless
   location <4, 3, -1>
   look_at <0, 0, 0>
Tor Olav
http://subcube.com
Date: 11 Jul 2009 09:48:56
Message: <4a589848@news.povray.org>
Tor Olav Kristensen wrote:
>> After getting a nice result with Alain's function I'm not going to dig
>> too deeply into the math trying to get that function to work, but thanks.
Now maybe this could be interesting for you:
#version 3.6;
#declare R = 2;
#declare pA = < R,  0,  R>;
#declare pB = <-R, -1,  R>;
#declare pC = <-R,  0, -R>;
#declare pD = < R,  1, -R>;
#declare Ax = pA.x;
#declare Ay = pA.y;
#declare Az = pA.z;
#declare Bx = pB.x;
#declare By = pB.y;
#declare Bz = pB.z;
#declare Cx = pC.x;
#declare Cy = pC.y;
#declare Cz = pC.z;
#declare Dx = pD.x;
#declare Dy = pD.y;
#declare Dz = pD.z;
#declare S = 1.0;
#declare Fn = function { exp(-S*(x*x + y*y + z*z)) }
#declare FnA = function { Fn(1.0*x, 1.0*y, 1.0*z) }
#declare FnB = function { Fn(0.5*x, 0.5*y, 0.5*z) }
#declare FnC = function { Fn(3.0*x, 1.0*y, 1.0*z) }
#declare FnD = function { Fn(1.5*x, 1.5*y, 1.5*z) }
isosurface {
   function {
     y
     + FnA(x - Ax, y - Ay, z - Az)
     - FnB(x - Bx, y - By, z - Bz)
     - FnC(x - Cx, y - Cy, z - Cz)
     - FnD(x - Dx, y - Dy, z - Dz)
   max_gradient 4
   contained_by { box { -<100, 2, 100>, <100, 2, 100> } }
light_source {
   <1, 2, -2>*100
   colour White*1.4
   shadowless
   location <0, 2, -3>*10
   look_at <0, 0, 0>
   angle 20
Tor Olav
http://subcube.com
