POV-Ray : Newsgroups : povray.general : <no subject> Server Time
21 Jan 2026 08:06:51 EST (-0500)
  <no subject> (Message 1 to 6 of 6)
Subject: <no subject>
Date: 8 Jul 2009 05:30:00
Message: <web.4a546647c23a6d95fbac4ff0@news.povray.org>
Hello everybody, I need a little help with this.
The following code works fine:
  background { color rgb <.5, .4, .3> }
  #declare Rnd_1 = seed (1153);
    location <3, 2, -3>
    look_at  <0, 0,  0>
  light_source {<100,200,-100> colour rgb 1}
  #macro ship ()
    #declare n = 1;
    #while ( n < 800 )
             box { <0,0,0>,<1,1,1>
             pigment{rgb .5}
             finish { phong 1 }
             scale <rand(Rnd_1)/5,rand(Rnd_1)/2,rand(Rnd_1)*1.5>
             translate <rand(Rnd_1)/2,rand(Rnd_1)/2,rand(Rnd_1)*4>
      #declare n = n + 1  ;
  ship()
but if I try: object { ship () translate <.1,0,0> } on the last line I get a
parse error, whats wrong? thanks in advance!
Subject: Re: <no subject>
Date: 8 Jul 2009 05:35:00
Message: <web.4a5467c36f92e8565fbac4ff0@news.povray.org>
woops... sorry about the "no subject" thing.
NOTE: if I remove the while-end loop code works fine.
Date: 8 Jul 2009 05:48:20
Message: <4a546b64$1@news.povray.org>
"MadKairon" <nomail@nomail> wrote in message
news:web.4a546647c23a6d95fbac4ff0@news.povray.org...
>  camera {
>    location <3, 2, -3>
>    look_at  <0, 0,  0>
>  #macro ship ()
>    #declare n = 1;
>    #while ( n < 800 )
>             pigment{rgb .5}
>             finish { phong 1 }
>    #end
>  #end
>  ship()
> a
With the #while loop in place your macro returns a number of objects (800
boxes) rather than an object, so when it hits the second object it should
complain. You can use a union:
union { ship () translate <.1,0,0> }
or you could wrap your #while loop in a union statement within the macro, in
which case it returns a single consolidated object which is a union of your
800 boxes and your object statement should then work fine.
Chris B.
Date: 8 Jul 2009 06:20:00
Message: <web.4a5472896f92e8565fbac4ff0@news.povray.org>
> Regards,
> Chris B.
.... and I keep learning stuff about object oriented programming, i just wanted
to render some boxes lol. wraping the loop in a union statement works great!
Thanks for the fast answer!!
Date: 8 Jul 2009 06:40:04
Message: <4a547784$1@news.povray.org>
news:web.4a5472896f92e8565fbac4ff0@news.povray.org...
>> in
>> your
>> Regards,
>> Chris B.
> wanted
> great!
Strictly speaking it's procedural programming/scripting with POV-Ray
objects, the term Object Oriented programming carrying a whole lot of other
connotations ;).
Date: 8 Jul 2009 19:35:01
Message: <web.4a552c146f92e856de52d56d0@news.povray.org>
>   #macro ship ()
>     #declare n = 1;
>     #while ( n < 800 )
>     #end
>   #end
>   ship()
Let's look at what this gives you: The macro has a loop, which creates a lot of
boxes (800, to be precise); so your macro invocation "ship()" is replaced by
something like:
    box {...}
    box {...}
    box {...}
    box {...}
At scene level, this is perfectly fine: It gives you 800 separate, individual
boxes. But the other syntax would give you:
    object {
      box {...}
      box {...}
      box {...}
      box {...}
This doesn't work, because the object {...} statement can only deal with a
single object. What you need is a union{...} or merge{...}, i.e.:
Or, better yet, change the macro to include the union{} statement:
    #macro ship ()
      union {
        #declare n = 1;
        #while ( n < 800 )
As this is now a valid single object (even though comprised of multiple
objects), you can now invoke it as you originally intended:
