POV-Ray : Newsgroups : povray.general : POV-Ray not parsing Server Time
5 Mar 2026 16:51:33 EST (-0500)
  POV-Ray not parsing (Message 1 to 5 of 5)
Subject: POV-Ray not parsing
Date: 18 Jun 2009 18:10:01
Message: <web.4a3abb33e5faceb097074f4f0@news.povray.org>
   I have often had the problem that POV-Ray for Windows does not succeed in
parsing what seems to be correct code. For example, with the latest Windows
version, if I copy verbatim (cut-and-paste) the sky sphere example from the
docs (section 2.3.2.4),
  sky_sphere {
      gradient y
      color_map {
        [ 0.5  color CornflowerBlue ]
        [ 1.0  color MidnightBlue ]
      scale 2
      translate -1
with nothing else in the file, I get the messages below.
Appreciate any help. Thanks.
- Chris
Preset INI file is 'C:\Documents and Settings\cchang\My
Documents\POV-Ray\v3.6\ini\quickres.ini', section
is '[512x384, No AA]'.
Preset source file is 'C:\Documents and Settings\cchang\Desktop\test.pov'.
Redirecting Options
  All Streams to console..........On
  Debug Stream to console.........On
  Fatal Stream to console.........On
  Render Stream to console........On
  Statistics Stream to console....On
  Warning Stream to console.......On
Parsing Options
  Input file: C:\Documents and Settings\cchang\Desktop\test.pov (compatible to
version 3.62)
  Remove bounds........On
  Split unions.........Off
  Library paths:
    C:\Documents and Settings\cchang\My Documents\POV-Ray\v3.6\include
    C:\WINDOWS\Fonts
Output Options
  Image resolution 512 by 384 (rows 1 to 384, columns 1 to 512).
  Output file: C:\Documents and Settings\cchang\Desktop\test.bmp, 24 bpp (system
format)
  Graphic display......On  (gamma: 2.2)
  Mosaic preview.......Off
  CPU usage histogram..Off
  Continued trace......Off
Tracing Options
  Quality:  9
  Bounding boxes.......On   Bounding threshold: 3
  Light Buffer.........On
  Vista Buffer.........On   Draw Vista Buffer....Off
  Antialiasing.........Off
  Clock value:    0.000  (Animation off)
File: C:\Documents and Settings\cchang\Desktop\test.pov  Line: 5
File Context (5 lines):
      color_map {
Parse Error: Expected ']', undeclared identifier 'CornflowerBlue' found instead
Total Scene Processing Times
  Parse Time:    0 hours  0 minutes  0 seconds (0 seconds)
  Photon Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Render Time:   0 hours  0 minutes  0 seconds (0 seconds)
  Total Time:    0 hours  0 minutes  0 seconds (0 seconds)
CPU time used: kernel 0.01 seconds, user 0.01 seconds, total 0.02 seconds
POV-Ray finished
Subject: Re: POV-Ray not parsing
Date: 18 Jun 2009 18:30:00
Message: <web.4a3abea0aac246fec64c67c0@news.povray.org>
There's your problem. CornflowerBlue is not declared. Did you put
at the beginning (assuming CornflowerBlue is declared in colors.inc)?
Date: 18 Jun 2009 18:30:06
Message: <4a3abfee$1@news.povray.org>
Assuming you included colors.inc, I can only suggest reinstalling POV-Ray
(maybe your colors.inc is corrupted in some weird way)
cu!
Date: 19 Jun 2009 13:15:01
Message: <web.4a3bc688aac246fe7080f32a0@news.povray.org>
>   sky_sphere {
>     pigment {
>       gradient y
>       color_map {
>       scale 2
>       translate -1
(I guess you mean section 3.3.2.4.)
The docs sometimes don't mention the use of standard include files, such as
"colors.inc" in this case.
This typically leads to "Parse Error: Expected <WhatEver>, undeclared identifier
'<WhatElse>' found instead" messages.
Date: 19 Jun 2009 14:58:01
Message: <4a3bdfb9$1@news.povray.org>
"clipka" <nomail@nomail> wrote in message
news:web.4a3bc688aac246fe7080f32a0@news.povray.org...
>> the
The numbering in the online documentation and the Windows documentation
differs by one at the top level, so it's 2.3.2.4 in the online version and
3.3.2.4 in Windows.
So you're both right :-)
Chris B.
