POV-Ray : Newsgroups : povray.general : Sequence of images but not animation Server Time
5 Mar 2026 16:51:33 EST (-0500)
  Sequence of images but not animation (Message 1 to 7 of 7)
Subject: Sequence of images but not animation
Date: 18 Jun 2009 13:45:00
Message: <web.4a3a7a0cbf13d750d6bbb9d50@news.povray.org>
Hi. I have a povray file that has a few stuff in it, and I can use it to render
an image. One of the things is:
mesh { #include "mesh.inc" inside_vector <1, 0, 0> translate <0, -2, 0>}
, which is a file that includes a complex mesh in triangle forms.
Now I have a huge series of meshes numbered as follows:
mesh00000.inc
mesh00001.inc
mesh00002.inc
etc, all the way to about 800 or something.
How can I get a single povray file to render all images, changing the value of
the include file only for each seporate image?
serperate files. Oh, and the files should be saved as bmp format, same as the
input mesh. So mesh00000.bmp etc...
anyone?
Subject: Re: Sequence of images but not animation
Date: 18 Jun 2009 14:12:44
Message: <4a3a839c@news.povray.org>
> mesh00000.inc
> mesh00001.inc
> mesh00002.inc
> anyone?
I came across a similar problem a while ago while working on macros,
where I needed to call functions with different names depending on a
parameter. The way I got it to work, thanks to clipka, was using a
'parse literals' function:
#macro ParseLiteral(s)
   #declare ParseLiteralFile = "ParseLiteral_$$$.inc";
   #fopen ParseLiteral_FD ParseLiteralFile write
   #write (ParseLiteral_FD,s)
   #fclose ParseLiteral_FD
   #include ParseLiteralFile
This would work for you by calling:
ParseLiteral(concat("#include mesh", str(MeshNumber,-5,0), ".inc"))
where 'MeshNum' is your frame number.
If you're looking to output to the animation style sequence of files,
I'd recommend treating it like an animation with the proper frame usage
(+KFI, +KFF, etc), and using the current frame number as MeshNumber.
Hope this helps, and if I'm wrong with some of the syntax that you can
figure out the idea!
CShake
Date: 18 Jun 2009 14:15:01
Message: <web.4a3a8351989c16d853f3f7840@news.povray.org>
> mesh00000.inc
> mesh00001.inc
> mesh00002.inc
If you do use POV-Ray's animation rendering mechanisms, you can include the
fitting mesh as follows:
  #local MyFrameNumberStr = substr(str(100000+frame_number,0,0),2,5);
  #local MyMeshInc = concat("mesh", MyFrameNumberStr, ".inc");
  #include MyMeshInc
Voila. The somewhat complex definition of MyFrameNumberStr serves to enforce
leading zeros.
Specify the output file name as "mesh.bmp"; pretend that your frame number
ranges from 0 to 99999 (again to get those leading zeros) and just render the
subset you actually need.
The only thing is that they must all have the same resolution.
Date: 18 Jun 2009 14:35:00
Message: <web.4a3a87d5989c16d8d6bbb9d50@news.povray.org>
Thank you both for your prompt responses! You were very helpful :)
I will try out your suggestions later tonight, but from a first glance, they
both seem logical and feasible.
Thanks again. Now I can get my batch job started. ;)
Date: 18 Jun 2009 14:53:38
Message: <4a3a8d32@news.povray.org>
Yeah, ignore what I said here, it works for calling custom functions but
I forgot that you can simply specify the name of the file to include, no
need to go through this extra function. Go with clipka's reply, just
make sure you do the leading zeros correctly.
> #end
> CShake
Date: 18 Jun 2009 16:33:14
Message: <4a3aa48a@news.povray.org>
clipka <nomail@nomail> wrote:
> > mesh00000.inc
> > mesh00001.inc
> > mesh00002.inc
  That's a rather contrived way of doing it. There's a simpler way:
#include concat("mesh", str(frame_number, -5, 0), ".inc")
Date: 19 Jun 2009 13:00:01
Message: <web.4a3bc393989c16d87080f32a0@news.povray.org>
> > > mesh00000.inc
> > > mesh00001.inc
> > > mesh00002.inc
Revoco!
You're perfectly right. Looks like I browsed the str() documentation too
superficially.
But it's always good to know that in POV-Ray there's typically plenty of ways to
skin a cat :)
