POV-Ray : Newsgroups : povray.general : Skybox problem Server Time
18 May 2025 06:52:20 EDT (-0400)
  Skybox problem (Message 1 to 7 of 7)
Subject: Skybox problem
Date: 2 May 2009 20:10:00
Message: <web.49fce08dada293029cb8530@news.povray.org>
I have been using Pov-ray to generate textures for my Direct3D game and thought
it would be perfect for creating the 6 textures to be mapped to the skybox in
my game. Using a sky_sphere, I have the camera with a FOV of 90 degrees and
rotated the camera as needed and can line up all by the top and bottom textures
to the front texture.
This is how each texture generated by Pov-Ray with the camera rotated are lined
up:
      top
left-front-right-back
     bottom
The left texture lines up perfectly with the front, the front with the right and
the right with the back. But the top and bottom do not line up with the front
texture of the sky sphere.
These are the camera rotation angles I have used:
front=(0,180,0)
left=(0,-90,0)
back=(0,0,0)
right=(0,90,0)
up=(-90,90,0)
down=(90,90,0)
The camera setup I have is this:
    location <0,0,0>
    direction 0.5*z right x up 0.75*y
    look_at <0,0,1>
    rotate <0,0,0>}
Which is meant to give a FOV of 90 degrees.
Please help.
Subject: Re: Skybox problem
Date: 2 May 2009 21:15:00
Message: <web.49fcef6227a5a292cdcbe4680@news.povray.org>
"JS" <bos### [at] yahoocouk> wrote:
> camera {
>     location <0,0,0>
>     look_at <0,0,1>
>     rotate <0,0,0>}
> Please help.
I think you are having problems with the default setting for the sky vector
sky <0,1,0>
Transforming parallel to this vector can be a problem. You may need to declare
your camera for each view, taking this into acount.
Stephen S
Date: 2 May 2009 23:05:00
Message: <web.49fd08d327a5a29229cb8530@news.povray.org>
Thanks but could you go into more detail?
Date: 3 May 2009 02:28:33
Message: <49fd3991$1@news.povray.org>
> up:
>       top
>      bottom
> front=(0,180,0)
> left=(0,-90,0)
> back=(0,0,0)
> right=(0,90,0)
> up=(-90,90,0)
> down=(90,90,0)
> camera {
>     location <0,0,0>
>     look_at <0,0,1>
>     rotate <0,0,0>}
	You have an horizontal FOV of 90 degrees, but a smaller vertical
FOV. You should use "up y" instead of "up 0.75*y".
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
Date: 3 May 2009 04:53:34
Message: <49fd5b8e$1@news.povray.org>
For the camera declaration for each texture, you need to set the sky
vector so that it points in the direction that is "up" for each given
texture.
This is not a problem for the left, right, front, and back textures,
because up is the same direction, and the default value works.
Another thing:  Unless your skybox is shorter in the y-dimension than in
the x and z dimensions (that is, not a cube, but a flattish
paralleliped), you need to use square textures, and set the up and right
vectors in the cameras to the same lengths.
On the other hand, if you already know the directions that everything
should face (right goes this way, up goes this way, direction goes this
way), then using look_at and rotate will only make opportunity for
confusing code.  It's better to spell out the camera vectors explicitly.
It appears that in your game, y is up and forward is in the negative z
direction, so your six camera declarations should look like this:
// forward
   right -x
   up y
   direction -z*.5
   location 0
// behind
   right x
   up y
   direction z*.5
   location 0
// left
   right -z
   up y
   direction x*.5
   location 0
// right
   right z
   up y
   direction -x*.5
   location 0
// top
   right -x
   up z
   direction y*.5
   location 0
// bottom
   right -x
   up -z
   direction -y*.5
   location 0
Render these to square images, and it should work.
Hope this helps,
John
Date: 3 May 2009 10:20:00
Message: <web.49fda7af27a5a29229cb8530@news.povray.org>
Thanks but the bottom shows when you look down:
http://img238.imageshack.us/my.php?image=mydreamskyboxproblem.png
(Those couple of grey lines are rain.)
This is strange as the bottom does line up with the forward image. Also, my
fault, z should be positive for forward, not negative.
Date: 3 May 2009 12:40:00
Message: <web.49fdc84b27a5a29229cb8530@news.povray.org>
I hope I got this right, so that forward is Z positive:
#declare camForward=
   right x
   up y
   direction z*.5
   location 0
#declare camBehind=
   right -x
   up y
   direction -z*.5
   location 0
#declare camBottom=
   right x
   up z
   direction -y*.5
   location 0
#declare camTop=
   right x
   up -z
   direction y*.5
   location 0
#declare camLeft=
   right z
   up y
   direction -x*.5
   location 0
#declare camRight=
   right -z
   up y
   direction x*.5
   location 0
And I found that the bottom texture has to be rotated 270 degrees, I'm not sure
why, maybe something to do with the polygons in the skybox.
