Hello all POV experts
I'm a new user and wold like to create a "glass" sphere with an image on the
surface.
Wandering here and there and reading the documentation, I succeeded in creating
the below added code. It would be nice, apart from the reflection of the bitmap
to the back of the inner surface giving unwanted reflections.
You see I added two image_maps on the front and on the back, shifted 180 deg. to
see in transparency the back of the bitmap on the other side.
Reflection are a catastrophe!!!! What couuld I do? any suggestion?
Thank You
Massimo
Attached the code I used
#include "skies.inc"
sky_sphere { S_Cloud3 }
location <0, 2, -5>
look_at <0,0, 0>
light_source {
<0, -12, 10>
color White
shadowless
light_source {
<0, 0, -10>
color White
shadowless
sphere{ <0,0,0>, 1
texture{ pigment { color rgbf <0.9, 0.9, 0.9, 0.8> } // transparent sphere
finish {
reflection 0.2
refraction 1.0
ior 1
phong 0.4
} // end of texture 1
texture{ pigment{
image_map{ gif "POV-Ray_215.gif"
map_type 0
once
filter all 1
translate<-0.5,-0.2>
scale<2.5,1>*0.7
} // end pigment
} // end of texture 2
texture{ pigment{
map_type 0
once
filter all 1
translate<-0.5,-1>
scale<2.5,1>*0.7
rotate<0,180,0>
} // end pigment
} // end of texture 3
} // end of sphere ------------------
> surface.
Three things I noticed immediately, which aren't part of the problem, but which
you may want to take care of down the line:
- I was not aware that refraction and ior were allowed in a finish
block. These are probably holdovers for backwards compatibility,
and should be moved or eliminated.
- ior belongs in an interior block, but even so, ior 1 has no effect.
Specifically, 1 is the IOR of a vacuum, and is POV-Ray's default.
- I don't know what refraction 1.0 does in this context. In a photon
{ target } block, it activates refraction caustics, but since you
have no global_settings { photons{} } block, it would have no effect.
Also recommend global_settings { assumed_gamma 1 }, which will brighten up your
scene considerably.
________________________
Very little of what you are seeing is reflection. An image map extends forever
along the z-axis in both directions, so even with reflection 0.0 and no 2nd
image map, you'd see the image map on both the near and far surfaces of the
sphere. With the 2nd image map, you get the quad effect that you're seeing.
Two solutions you may want to consider are:
- Use an object pigment to clip the image map to one side of the x-y
plane.
#declare Base_pigment = pigment
{ object
{ plane { z, 0 }
pigment { rgbt 1 }
pigment
{ image_map
map_type 0 once filter all 1
Then use Base_pigment in place of your current image_map block.
- Use u-v mapping. If you choose this method, you should not rotate
the image map, but scale and translate in the x directions.
Maybe "inside_texture" will get you where you want to go, allowing you to
specify a different reflectance for inside and outside.
> sphere{ <0,0,0>, 1
> finish {
> reflection 0.2
> refraction 1.0
> ior 1
> phong 0.4
Some additional (unsolicited) advice:
- "refraction" is actually not necessary; it's just a relic from old times (I
wonder where you got that from; it's not even mentioned in the online help
anymore as far as I can tell). The amount of refracted light is nowadays
controlled by the transmit & filter components of the pigment.
- For a realistic glass sphere, set ior to 1.3; the default value of 1 doesn't
do any refraction at all.
- use specular instead of phong (more realistic; AFAIK phong only takes into
account the position of the light source, while specular takes into account
both light source and camera position)
ThankYou all
Massimo nous illumina en ce 2009-03-11 13:40 -->
> surface.
> Thank You
> Massimo
> camera {
> location <0, 2, -5>
> look_at <0,0, 0>
> light_source {
> <0, -12, 10>
> color White
> shadowless
> light_source {
> <0, 0, -10>
> color White
> shadowless
> sphere{ <0,0,0>, 1
> finish {
> reflection 0.2
> refraction 1.0
> ior 1
> phong 0.4
> texture{ pigment{
> map_type 0
> once
> filter all 1
> scale<2.5,1>*0.7
> } // end pigment
> texture{ pigment{
> map_type 0
> once
> filter all 1
> translate<-0.5,-1>
> scale<2.5,1>*0.7
> rotate<0,180,0>
> } // end pigment
Another way to map your image is to use the warp.
texture{ pigment{
warp{spherical image_map{ gif "POV-Ray_215.gif"
once
filter all 1
scale<2.5,1>*0.7
} // end pigment
With "once" it will only apears once on the surface. Without it, it will get
tilled. You use the scale command to adjust the area the image will cover.
Without scale, it will go from one pole to the other and meet itself on the
back. Scale<0.25, 0.5, 1> will restrict it within 45 degree up and down and 90
degree around.
You know you've been raytracing too long when you look at a matrix transform and
know instantly what it does.
John VanSickle
