POV-Ray : Newsgroups : povray.general : mirrored object Server Time
18 May 2025 10:28:40 EDT (-0400)
  mirrored object (Message 1 to 8 of 8)
Subject: mirrored object
Date: 5 Mar 2009 09:55:01
Message: <web.49afe75ffca6fce7c9ee64130@news.povray.org>
Hello,
I have macro which draws some object and wonder if I can change it in a simple
way to create the same object but mirrored to some axis. I know it is possible
to swap all image along z-axis by specifing negative number for camera's
"right" property. I am thinking of almost the same result but only for
specified object.
Thanks in advance,
twister
Subject: Re: mirrored object
Date: 5 Mar 2009 09:56:45
Message: <49afe82d$1@news.povray.org>
I think I've seen a way to use matrix transforms that flip axes, like from
lefthand to righthand, etc...
I don't know if that is useful or not...
ian
"twister" <twi### [at] o2pl> wrote in message
news:web.49afe75ffca6fce7c9ee64130@news.povray.org...
> Hello,
> simple
> possible
> specified object.
> Thanks in advance,
> twister
Date: 5 Mar 2009 09:59:37
Message: <49afe8d9@news.povray.org>
  How about simply doing a scale <-1, 1, 1>?
Date: 5 Mar 2009 10:00:04
Message: <49afe8f3@news.povray.org>
> specified object.
  scale <-1, 1, 1>
Date: 5 Mar 2009 10:15:00
Message: <web.49afeb54c45341a8c9ee64130@news.povray.org>
I knew there must be very simple solution. Thanks a lot!!!
twister
Date: 5 Mar 2009 10:40:00
Message: <web.49aff218c45341a8f567c3de0@news.povray.org>
> specified object.
You mean, like "scale <1,1,-1>"? ;)
(You can also write "scale -z", but the compiler will warn you because, although
both you and the compiler know what it is meant to do, it is strictly not the
same. Taken literally, it would reduce your object to one infinitely thin
line... of course POV is clever enough to know that this is quite definitely
not what you want :))
Date: 5 Mar 2009 12:15:38
Message: <49b008ba@news.povray.org>
  This is the first time I see POV-Ray called "compiler"... ;)
Date: 6 Mar 2009 07:05:01
Message: <web.49b11130c45341a88f505d3e0@news.povray.org>
Nitpicker! :P
