POV-Ray : Newsgroups : povray.general : Spline parameters Server Time
22 May 2025 11:36:46 EDT (-0400)
  Spline parameters (Message 1 to 6 of 6)
Subject: Spline parameters
Date: 24 Feb 2009 08:00:00
Message: <web.49a3ee97d251b6ec9ee64130@news.povray.org>
Hi all,
Maybe it is kind of silly question, but as far as I am new to PovRay I can't
deal with it. The thing is I don't understand how the list of values (followed
by points) in the spline declaration works. For linear_spline these values
doesn't matter what is quite obvious. But for quadratic_ or natural_spline they
matters. It is written in documentation they are some parameters, but nothing
more. Where will I find some helpful informationa about spline declarations?
Because otherwise I don't know what I do. Thanks in advance.
Best regards,
Twister
Subject: Re: Spline parameters
Date: 24 Feb 2009 09:05:09
Message: <49a3fe95$1@news.povray.org>
"twister" <twi### [at] o2pl> wrote in message
news:web.49a3ee97d251b6ec9ee64130@news.povray.org...
> Hi all,
> can't
> (followed
> they
> nothing
> declarations?
> Best regards,
> Twister
I take it that, in the spline definition:
    spline {
      [SPLINE_IDENTIFIER] |
      [SPLINE_TYPE] |
      [Val_1, <Point_1>[,]
       Val_2, <Point_2>[,]
you're asking about Val_1, Val_2 etc.
These are fairly arbitrary values that you can think of in a number of
different ways. It's like a 4th dimension that you can use to index how far
through the spline you are, but you can really choose what you consider this
index to represent.
The help suggests thinking of it as time, which is handy when you do
animations. I usually set it so that the first physical point on the spline
starts at 0 and the last point ends at 1. This means that in animations it's
easy to use it with the clock variable to step along the spline in equally
sized time slices.
When defining a curve in a scene (rather than when using it for animation)
you can just consider it as an amount that represents how far through the
spline definition you are. So if you still start the spline at 0 and end at
1, then 0.5 can represent half way through the spline definition, though
it's important to realise that this is not a distance, so it may be nowhere
near the physical mid-point of the spline.
Any help?
Chris B.
Date: 24 Feb 2009 09:30:00
Message: <web.49a40439cf14bf60c9ee64130@news.povray.org>
> index to represent.
To be honest I cannot say these values are arbitrary ones because they have
strong impact on the spline shape. Besides, following spline is wrong and
povray returns an error: "Parse Error: Degenerate cylinder, base point = apex
point." It means I cannot define these values in whatever manner I like.
#declare mySpline = spline {
 quadratic_spline
 1, <0,0,0>,
 2, <1,1,0>,
 3, <2,1,0>,
> sized time slices.
I can think of these values as a "timestamps", but they shouldn't change the
spline shape!
> Any help?
Still confused...
> Regards,
> Chris B.
Date: 24 Feb 2009 10:31:55
Message: <49a412eb$1@news.povray.org>
news:web.49a40439cf14bf60c9ee64130@news.povray.org...
>> far
>> this
>> index to represent.
> have
> apex
> quadratic_spline
> 1, <0,0,0>,
> 2, <1,1,0>,
> 3, <2,1,0>,
By 'arbitrary' I meant they don't represent anything specific and can have
more or less any values that you like.
The above spline didn't return an error when I just pasted it into a scene
file and ran it through the parser and the error you mention relates to a
cylinder rather than a spline, so I suspect it was generated by another part
of your scene file.
>> spline
>> it's
>> equally
>> sized time slices.
> the
> spline shape!
I don't think they do change the shape of the spline.
>> Any help?
> Still confused...
Well it may be one of those things that just suddenly clicks when someone
describes it in a certain way, so I'll leave it to others to have a go.
Chris B.
Date: 24 Feb 2009 12:25:00
Message: <web.49a42cf2cf14bf602611931b0@news.povray.org>
Hi!
Have you read the documentation? - 2.3.1.1.1  Understanding The Concept of
Splines That's what made it click for me, as Chris B says.
I believe your problem might be related to the invisible control/shape points in
non-linear splines. Anyway, here's some example code on how I like to use
splines. I hope it's helpful.
-Peter
camera{location <3,1,-4> look_at <2,1,0>}
light_source{<1,2,-3>,1}
#local SP = 3; // SplinePoints
// Number of visible/real points in spline (not counting 0)
// Increase this as you increase the points in the spline
// declaration below, and it will automatically place the
// points in an evenly space between 0 and 1.
#local Resolution = 0.01;
// Increase/decrease to pick out less/more points from the
// spline. Try 0.1 or even 0.3-clock*0.25 and command line:
// +k +kff99
#declare Snake = spline{
cubic_spline
-1/SP,<-1,0,-1>, // Shape/control point
0/SP,<0,0,0>,
1/SP,<1,1,0>,
2/SP,<2,1,1>,
3/SP,<3,0,0>,
(SP+1)/SP,<4,-1,-1> // Shape/control point
// And now, a small while loop to demonstrate.
#local Variable = 0;
#while (Variable < 1)
        #local Point = Snake(Variable);
        sphere{Point,0.1 pigment {rgb y}}
        #ifdef(Point2)
                cylinder{Point,Point2,0.1 pigment {rgb y}}
        #local Point2 = Point;
#local Variable = Variable+Resolution;
Date: 24 Feb 2009 15:45:00
Message: <web.49a45b27cf14bf60ddaa9d30@news.povray.org>
Did you already check out section 2.3.1.1.1 ("Understanding The Concept of
Splines") of the online help?
