POV-Ray : Newsgroups : povray.general : A piece of Radiosity Voodoo against splotches Server Time
5 Mar 2026 22:54:24 EST (-0500)
  A piece of Radiosity Voodoo against splotches (Message 1 to 2 of 2)
Subject: A piece of Radiosity Voodoo against splotches
Date: 27 Dec 2008 18:05:01
Message: <web.4956b3ddf2882ca6513c86b90@news.povray.org>
Here's a piece of undocumented Radiosity Voodoo:
If you get stray black splotches in your shot, increasing the global
max_trace_level will reduce their number.
I hope it doesn't kill your render speed though...
These stray splotches are due to an implementation blunder in POV-Ray, and
basically appear in any scene that has reflection or refraction; I'll make sure
it gets fixed in the next 3.7 beta.
I guess these are the ultimate source of a lot frustrating fights with POV
radiosity settings - because to my knowledge there is *no* other way to get rid
of them, regardless how high you crank up the radiosity quality. If you manage
to reduce their number they will grow; If you manage to shrink them, they will
multiply; if you manage to level them out a bit, they will spread out like
pancakes.
The only thing that really helps is toying around with the global
max_trace_level.
There is also a potential similar issue related to global and/or radiosity
adc_bailout; However, I haven't investigated this in detail yet, so I currently
cannot give any advice on how to set these. However, toying around with them may
help as well.
Subject: Re: A piece of Radiosity Voodoo against splotches
Date: 28 Dec 2008 05:37:38
Message: <495756f2$1@news.povray.org>
   You're absolutely right: I discovered this cause of artifacts while doing
some tests last month, and I was going to publish an article about it on my
site, but Real Life got in the way and I forgot about it...
   Usually, just increasing a bit the default max_trace_level to 7 is
enough, and it doesn't have much impact on regular scenes. It is really
evident when you have a perfectly square room with reflecting walls: the
corners receive a lot of artifacts. So I figured out it was something to do
with max_trace_level without looking at the code... ;)
Jaime
