POV-Ray : Newsgroups : povray.general : Texture for "X-ray" type image Server Time
24 Aug 2025 17:32:56 EDT (-0400)
  Texture for "X-ray" type image (Message 1 to 8 of 8)
Subject: Texture for "X-ray" type image
Date: 12 Dec 2008 08:00:00
Message: <web.49425fa548f3798df1d58de20@news.povray.org>
Hi all. I am trying to make a texture for producing images that look a bit like
x-ray pictures (see for example
http://cebas.com/products/feature.php?UD=10-7888-33-788&PID=45&FID=401 for what
I mean). For doing this I think I need a transparent or filter value that
depends on the surface normal. The surface should be transparent when facing
the camera and opaque when viewed from the side. Is it possible to specify this
in some simple way?
Sincerely,
Ulf
Subject: Re: Texture for "X-ray" type image
Date: 12 Dec 2008 08:31:41
Message: <494267bd$1@news.povray.org>
"uekstrom" <uekstrom at gmail dot com> wrote in message
news:web.49425fa548f3798df1d58de20@news.povray.org...
> like
> what
> facing
> this
> in some simple way?
not, afaik, in the official POV-Ray, very easily so in MegaPOV (aoi-pattern)
cu!
Date: 12 Dec 2008 08:32:24
Message: <494267e8@news.povray.org>
> in some simple way?
  The official povray doesn't have an angle-of-incidence pattern, but it
does have a slope pattern:
http://povray.org/documentation/view/3.6.1/393/
  You can most probably achieve the effect you want with that pattern, by
making the slope vector point towards the camera. (But because it's not an
angle-of-incidence patter, it won't work properly for reflections, etc.)
Date: 12 Dec 2008 08:35:00
Message: <web.4942684d5c4bb01a81c811d20@news.povray.org>
> in some simple way?
> Sincerely,
> Ulf
the aoi (angle of incidence) pattern that is in megaPOV would serve best for
this.  However, without megaPOV, you can adapt the 'slope' pattern, you will
just need to play around with the numbers.
-tgq
Date: 12 Dec 2008 09:35:00
Message: <web.4942762f5c4bb01a9c3fc0810@news.povray.org>
Thanks, it worked fine with the ios and an appropriate color_map! (See
http://dustyattic.org/pool/orbitals.png for a simple example)
I used the texture below. It didn't look very good with fewer entries in the
color map.
#declare gam = 4;
#declare xray = texture{
  aoi
         color_map {
          [0.00 color rgbt <1,1,1,1-pow(0.0,gam)/pow(0.5,gam)> ]
          [0.05 color rgbt <1,1,1,1-pow(0.05,gam)/pow(0.5,gam)> ]
          [0.10 color rgbt <1,1,1,1-pow(0.10,gam)/pow(0.5,gam)> ]
          [0.15 color rgbt <1,1,1,1-pow(0.15,gam)/pow(0.5,gam)> ]
          [0.20 color rgbt <1,1,1,1-pow(0.20,gam)/pow(0.5,gam)> ]
          [0.25 color rgbt <1,1,1,1-pow(0.25,gam)/pow(0.5,gam)> ]
          [0.30 color rgbt <1,1,1,1-pow(0.30,gam)/pow(0.5,gam)> ]
          [0.35 color rgbt <1,1,1,1-pow(0.35,gam)/pow(0.5,gam)> ]
          [0.40 color rgbt <1,1,1,1-pow(0.40,gam)/pow(0.5,gam)> ]
          [0.45 color rgbt <1,1,1,1-pow(0.45,gam)/pow(0.5,gam)> ]
          [0.50 color rgbt <1,1,1,1-pow(0.50,gam)/pow(0.5,gam)> ]
          [1.00 color rgbt <1,1,1,1> ]
 finish{ ambient 1 }
Ulf
Date: 12 Dec 2008 10:52:44
Message: <494288cc$1@news.povray.org>
news:web.4942762f5c4bb01a9c3fc0810@news.povray.org...
Nice.
I've posted a quick example of using the slope pattern on
povray.binaries.images.
Chris B.
Date: 12 Dec 2008 11:20:01
Message: <web.49428eeb5c4bb01a81c811d20@news.povray.org>
> color map.
> #declare gam = 4;
>  pigment {
>   aoi
>          color_map {
>  finish{ ambient 1 }
> Ulf
Looks good.
One thing you can do rather than having multiple entries is use the poly_wave
waveform (rather than the default linear waveform) which should be able to do
axactly what you are doing with multiple entries (only better as it would be a
continuous nonlinear waveform whereas you have many smaller linear waveforms)
-tgq
Date: 13 Dec 2008 10:14:07
Message: <4943d13f@news.povray.org>
"uekstrom"  wrote in message
<web.49425fa548f3798df1d58de20@news.povray.org>:
Are you sure that is how x-rays look like? Intuitively, I would have thought
that only the thickness would have any influence. Surfaces seen from the
side are more opaque because the rays traverses them diagonally. Such an
effect could probably be obtained with an absorbing medium, or maybe with an
emitting one.
