POV-Ray : Newsgroups : povray.general : "volume" lights Server Time
6 Mar 2026 00:21:14 EST (-0500)
  "volume" lights (Message 1 to 9 of 9)
Subject: "volume" lights
Date: 7 Dec 2008 06:35:01
Message: <web.493bb430a1eea09fa3cd40010@news.povray.org>
One of the limitations of area lights is that the light they cast is different
depending on the angle. What is the best way to create a light that casts soft
shadows, but does so equally in each direction?
-Mike
Subject: Re: "volume" lights
Date: 7 Dec 2008 08:03:45
Message: <493bc9b1$1@news.povray.org>
Hash: SHA1
	Add "orient" to your area light and it will turn to always face in
the right direction.
		Jerome
mailto:jeb### [at] freefr
http://jeberger.free.fr
Jabber: jeb### [at] jabberfr
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iEYEARECAAYFAkk7yicACgkQd0kWM4JG3k+OMwCcD83E24cl6GwKoMRtlvkMwYNt
1H4AoJkA+BG8zVAtHC1HLSpVDCSm2XQ/
=L1dx
-----END PGP SIGNATURE-----
Date: 7 Dec 2008 08:25:00
Message: <web.493bcdf0991b1dd0bb691c840@news.povray.org>
This doesn't eliminate the problem whereby the light source only casts the
shadows properly in a single direction.
-Mike
Date: 7 Dec 2008 09:01:10
Message: <493bd726$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.493bcdf0991b1dd0bb691c840@news.povray.org...
uhm... that's *exactly* what it eliminates, no?
cu!
Date: 7 Dec 2008 11:35:01
Message: <web.493bfb07991b1dd0bb691c840@news.povray.org>
No, it doesn't. I want the light source to light an entire scene evenly.
Rotating the light source just means the angle has *changed*. It doesn't
*increase* the number of angles. It still only points to one location.
-Mike
Date: 7 Dec 2008 11:40:34
Message: <493bfc82@news.povray.org>
"orient" rotates the light to face in the right direction *individually for
every ray*. Each time the shadow is calculated, the area light will be
pointing at the point being tested.
Date: 7 Dec 2008 13:10:00
Message: <web.493c1113991b1dd0bb691c840@news.povray.org>
Oh! Awesome! I didn't realize that.
-Mike
Date: 7 Dec 2008 13:11:29
Message: <493c11d1@news.povray.org>
Sounds like you want to broaden the area of the 'grid' of lights.  Best
results are usually around 10% of the distance to the light source.  If
you want more softness than that you can have by increasing the area of
the grid, but need to seriousless increase the 'number' of lights in the
grid too.  Use 'adaptive' in that case.  Remember this only affects
shadows though, the highlight will still be a point.  This features gets
good effects in a broad range of normal cases.  THe serach for
convincing soft diffuse lighting has lead many to improvise 'dome
lighting' systems.  Just search the ng's
Date: 7 Dec 2008 14:00:01
Message: <web.493c1cc3991b1dd08f4fceef0@news.povray.org>
> -Mike
Adding the "circular" and "orient" keywords to your area lights will do exactly
what you're looking for.
