POV-Ray : Newsgroups : povray.general : Blobs help Server Time
25 Aug 2025 01:21:52 EDT (-0400)
  Blobs help (Message 1 to 9 of 9)
Subject: Blobs help
Date: 10 Nov 2008 12:55:01
Message: <web.4918748ab3c4f15b1f5ffef0@news.povray.org>
The example blob function at the end of the isosurface tutorial behaves
differently at different scales, as can be seen in the example below. This is
not a problem with the built-in blob object. I was wondering if anyone could
provide a better formula for when using isosurfaces? Thanks!
// Begin
#version 3.6;
#include "functions.inc"
#include "math.inc"
#include "Axes_macro.inc"
#declare Scene_scale = frame_number;
global_settings
 assumed_gamma 1.0
 max_trace_level 5
#declare screen_scale = 1;
camera
 #local CameraDistance = 10;
 #local ScreenArea = 6;
 #local AspectRatio = image_width/image_height;
 orthographic
 location -z*CameraDistance
 direction z*CameraDistance
 right     x*ScreenArea*AspectRatio
 up        y*ScreenArea
 rotate x*asind(tand(30))
// rotate x*90
 rotate y*45
 scale Scene_scale
background { color rgb <0.6,0.7,1.0> }
light_source
 <0, 0, 0>            // light's position (translated below)
 color rgb <1, 1, 1>  // light's color
 translate <-30, 30, -30>
 shadowless
 scale Scene_scale
light_source
 rotate y * 90
 shadowless
 scale Scene_scale
plane { y,0 pigment {color rgbt 1/2}}
#declare Blob_threshold = 0.5;
#declare Blob_start = 1;
#declare fn_A = function { pow(x+Scene_scale/2,2) + pow(y+Scene_scale/2,2) +
pow(z+Scene_scale/2,2) - pow(Scene_scale,2) };
#declare fn_B = function { pow(x-Scene_scale/2,2) + pow(y-Scene_scale/2,2) +
pow(z-Scene_scale/2,2) - pow(Scene_scale,2) };
#declare fn_C = function { Blob_start + Blob_threshold }
difference
 isosurface
  function
   fn_C(x,y,z)
   - pow(Blob_threshold, fn_A(x,y,z))
   - pow(Blob_threshold, fn_B(x,y,z))
  threshold 0
  accuracy 0.001*Scene_scale
  max_gradient 4
  contained_by { sphere { 0, 2 * Scene_scale } }
 pigment {color rgb x}
// End
Subject: Re: Blobs help
Date: 10 Nov 2008 13:59:32
Message: <49188494@news.povray.org>
Shouldn't this be something like:
#declare fn_A =
   function {
     pow(x/Scene_scale+1/2,2) +
     pow(y/Scene_scale+1/2,2) +
     pow(z/Scene_scale+1/2,2) -
     1 };
etc?
Date: 10 Nov 2008 19:50:01
Message: <web.4918d5ff2cced725b9b4c0ae0@news.povray.org>
> #declare fn_A =
>    function {
>      1 };
> etc?
Could you please explain why?
-Mike
Date: 10 Nov 2008 20:26:27
Message: <4918DF43.1030001@yahoo.com>
S
>> #declare fn_A =
>>    function {
>>      1 };
>> etc?
> -Mike
So the function "spreads out" as the multiplication factor changes, but that the value
at a given scaled value of (x,y,z) doesn't change.
Date: 10 Nov 2008 20:26:31
Message: <4918DF48.80003@yahoo.com>
S
>> #declare fn_A =
>>    function {
>>      1 };
>> etc?
> -Mike
Date: 10 Nov 2008 21:25:00
Message: <web.4918ec8c2cced725aa1dde120@news.povray.org>
I found to equations that fit the bill. However, I don't know which one to
choose. Both are said to model the behavior of electric fields. One is from
Wikipedia, the other is from a GameDev.net article.
Here is the first:
#declare Blob_threshold = pow(2,frame_number-3);
#declare fn_A = function { 1.5*Scene_scale / sqrt(pow(x+1*Scene_scale,2) +
pow(y,2) + pow(z,2)) };
#declare fn_B = function { 1.5*Scene_scale / sqrt(pow(x-1*Scene_scale,2) +
#declare fn_C = function { Blob_threshold };
#declare fn_D = function { fn_A(x,y,z) + fn_B(x,y,z) - fn_C(x,y,z) };
#declare fn_E = function { max(0,min(1,fn_D(x,y,z))) };
Here is the second:
#declare Blob_threshold = clock;
#declare fn_A = function { 1.5*Scene_scale / (pow(x+1*Scene_scale,2) + pow(y,2)
+ pow(z,2)) };
#declare fn_B = function { 1.5*Scene_scale / (pow(x-1*Scene_scale,2) + pow(y,2)
+ pow(z,2)) };
Which of the two is correct in terms of modeling nature?
-Mike
Date: 10 Nov 2008 21:25:01
Message: <web.4918ecf12cced725aa1dde120@news.povray.org>
> S
> >> #declare fn_A =
> >>    function {
> >>      1 };
> >> etc?
> > -Mike
value at a given scaled value of (x,
I can't argue as to its merits. It is simply the function I copied from the
isosurface tutorial.
-Mike
Date: 12 Nov 2008 21:30:00
Message: <web.491b902d2cced725ab9780f0@news.povray.org>
Success!
I managed through trial and error to eliminate the variables that caused the
function to be affected by scale.
#declare fn_A = function { (pow(x+1*Scene_scale,2) + pow(y,2) + pow(z,2) -
pow(1.5*Scene_scale,2)) / pow(Scene_scale,2) };
#declare fn_B = function { (pow(x-1*Scene_scale,2) + pow(y,2) + pow(z,2) -
#declare fn_C = function { (Blob_threshold + Blob_start) }
#declare fn_D = function { pow(Blob_threshold, fn_A(x,y,z)) +
pow(Blob_threshold, fn_B(x,y,z)) - fn_C(x,y,z) };
The next step is to duplicate the results of the internal "blob" object.
Date: 19 Nov 2008 03:10:00
Message: <web.4923c93e2cced7254c536f040@news.povray.org>
> Success!
I've compiled what I've learned about blobs, here:
http://www.geogebra.org/en/upload/files/english/Michael_Horvath/Metaballs/geogebra_metaballs.htm
I'd appreciate any insights you might have regarding this class of shapes.
-Mike
