POV-Ray : Newsgroups : povray.general : Check if objects intersect Server Time
25 Aug 2025 01:24:18 EDT (-0400)
  Check if objects intersect (Message 1 to 6 of 6)
Subject: Check if objects intersect
Date: 8 Nov 2008 20:50:00
Message: <web.4916415194a473741f7585b80@news.povray.org>
Is there a function that returns true if two objects intersect? Thanks!
-Mike
Subject: Re: Check if objects intersect
Date: 8 Nov 2008 22:07:06
Message: <491653da@news.povray.org>
I don't think that's technically possible to do with arbitrary objects...
Date: 9 Nov 2008 03:45:00
Message: <web.4916a1e7205550c9d79f8a540@news.povray.org>
That's too bad. It would be cool to be able to check whether an intersection is
empty or not.
-Mike
Date: 9 Nov 2008 04:16:47
Message: <4916aa7f$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.4916415194a473741f7585b80@news.povray.org...
> -Mike
I don't think there's any universally reliable way to do that.
In some circumstances you may be able to construct an approach using the
min_extent and max_extent functions with the object you get by using an
intersection of the two objects you're interested in to help determine this,
but these functions use the bounding box of the resulting object and, as the
help says: "this is not perfect, in some cases (such as CSG intersections
and differences or isosurfaces) the bounding box does not represent the
actual dimensions of the object".
Given this, you could (with a considerable degree of caution) construct a
macro that may be able to serve your particular needs by combining the
min_extent and max_extent functions and the trace function. If the extent
values returned are very large (10000000000), then the objects don't
intersect. If any of the dimensions is zero, then they don't intersect.
Otherwise you'd need to fire a grid of lines through the space using the
trace function to see if any hit the object. If any hit the intersection
object, then it exists. If none hit the object it's still possible that the
original objects intersected, but that your rays were'nt close enough
together to hit it.
I've pasted in a bit of SDL below that may help if you wish to explore this
approach.
Hope that helps.
Chris B.
camera {location <0,0,-6> look_at 0}
light_source { <0,100,-10>, 1 }
#declare MyObject = intersection {
  sphere {y,1}
  sphere {-x,0.01}
  pigment {rgb 1}
#declare MyObject_Min = min_extent(MyObject);
#declare MyObject_Max = max_extent(MyObject);
#declare MyObject_Dim = MyObject_Max - MyObject_Min;
#debug concat(" Min extents: ",vstr(3,MyObject_Min,","3,3),"\n")
#debug concat(" Max extents: ",vstr(3,MyObject_Max,","3,3),"\n")
#debug concat(" Dimensions:  ",vstr(3,MyObject_Dim,","3,3),"\n")
#if (MyObject_Max.x>1000000)
  #debug "Clear Miss\n"
#if (MyObject_Dim.x=0 | MyObject_Dim.y=0 | MyObject_Dim.z=0)
  #debug "Miss\n"
// Otherwise use trace to test the object.
object {MyObject}
Date: 9 Nov 2008 05:25:00
Message: <web.4916b9eb205550c91da2db9f0@news.povray.org>
> together to hit it.
> approach.
> Hope that helps.
> Regards,
> Chris B.
Thank you very much for your excellent reply! I do not, however, want to go to
so much trouble at this time. I have decided that it is sufficient for my
purposes to approximate things by constructing "bounding spheres".
-Mike
Date: 9 Nov 2008 17:33:09
Message: <49176525@news.povray.org>
>> this,
>> the
>> the
>> together to hit it.
>> this
>> approach.
>> Hope that helps.
>> Regards,
>> Chris B.
> go to
> -Mike
I worked on this before...
this macro detects collisions of two objects.
It works by casting random rays at an intersection
some number of times.
While theoretically it could miss a collision, in
practice the sort of collisions it misses are
the sort of thing that are hard for the human eye
to see.
#macro collision(A B rez)
   #local result = false;
   #if (((min_extent(A).x > max_extent(B).x ) |
         (min_extent(B).x > max_extent(A).x ) |
         (min_extent(A).y > max_extent(B).y ) |
         (min_extent(B).y > max_extent(A).y ) |
         (min_extent(A).z > max_extent(B).z ) |
         (min_extent(B).z > max_extent(A).z ))=false)
      #local AB = intersection{object{A} object{B}};
      #local Mn = min_extent(AB);
      #local Mx = max_extent(AB);
      #local S1 = seed(1);
      #local cnt = 0;
      #while ((result = false) & (cnt < rez))
         #local Pt = VRand_In_Box(Mn, Mx, S1);
         #local Norm = <0,0,0>;
         #local Hit = trace(AB,<Pt.x,Mn.y-0.1,Pt.z>,y,Norm);
         #if (vlength(Norm)!=0)
            #local result = true;
         #else
            #local Hit = trace(AB,<Mn.x-0.1,Pt.y,Pt.z>,x,Norm);
            #else
               #local Hit = trace(AB,<Pt.x,Pt.y,Mn.z-0.1,>,z,Norm);
         #local cnt = cnt + 1;
   (result)
#declare sample1 = union {
   box {<0,0,0>,<1,1,1>}
   sphere{<0,1,0>,0.1}
   pigment{Red}
#declare sample2 = union {
   sphere{<1,0,0>,0.1}
   sphere{<0,0,0>,0.1}
   pigment{Blue}
   translate <-1.05,-0.085,0>
#local result = collision(sample1 sample2 1000);
object {sample1}
object {sample2}
union {
#switch (result)
   #case (0)
      text {ttf "tahoma.ttf" "Doesn't collide." 0.1,0}
   #break
   #case (1)
      text {ttf "tahoma.ttf" "Collides!" 0.1,0 }
   #break
   scale <0.2,0.2,1>
   translate <-1,-0.5,-1>
   pigment {Orange}
