POV-Ray : Newsgroups : povray.general : Shadow density Server Time
25 Aug 2025 01:44:05 EDT (-0400)
  Shadow density (Message 1 to 7 of 7)
Subject: Shadow density
Date: 24 Oct 2008 09:55:02
Message: <web.4901d2f89d477d5ce2381b720@news.povray.org>
Hi All!
Please help me anybody slove some issue. How I do to increase hilight in
shadowed areas without increasing global hightlight?
Thanks.
Subject: Re: Shadow density
Date: 24 Oct 2008 10:40:41
Message: <4901de69@news.povray.org>
"user" <ser### [at] gmailcom> schreef in bericht
news:web.4901d2f89d477d5ce2381b720@news.povray.org...
> Hi All!
> Thanks.
Radiosity is the best answer. If you want something faster (for testing for
instance) use an additional, shadowless light. For instance:
//start code
//main light:
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>*2  // light's color
  translate <-100, 10, -100>
//fill-in light:
light_source {
  color rgb <1, 1, 1>*0.3  // light's color
  translate <100, 10, -100>
  shadowless
//end code
Date: 24 Oct 2008 10:45:56
Message: <4901dfa4$1@news.povray.org>
user wrote:
> Hi All!
> Thanks.
I don't understand the question.  You balance ambient against the strength of external
lights.  Or, if you use radiosity, you adjust the strength.
You probably want to consider radiosity.
Date: 24 Oct 2008 12:05:24
Message: <ihs3g4hs7ttv5hhmndhv0r85b3cbjg6mdn@4ax.com>
On Fri, 24 Oct 2008 09:51:52 EDT, "user" <ser### [at] gmailcom> wrote:
>Hi All!
As well as what Thomas and Dan have said, a light group might be of use if it is
just one area you want to lighten. You would use it as a "fill light" that only
affects what is in the group.
See 3.4.8  Light Groups in the help.
Regards
Date: 24 Oct 2008 12:55:40
Message: <4901fe0c@news.povray.org>
"user" <ser### [at] gmailcom> wrote in message
> Hi All!
> Thanks.
In addition to what everyone else has already said you could:
Increase the ambient value on just the objects that the shadows are falling
on by using the ambient keyword in the finish blocks of the texture
statements for just those objects.
Add a light source in the vacinity of the objects that you wish to
illuminate more, with a fade_distance on the light source to prevent it from
illuminating areas further away.
And my favourite :-):
You can use two coincident copies of an object that casts a shadow, one with
no_shadow, the other with no_image. Then you can do whatever you like with
its shadows. You can produce partial shadows or very diffuse shadows from a
point light source. Or you can play tricks. The example below uses a filter
to tamper with the light as it passes through the 'no_image' copy of the
object, saturating anything blue in the 'shadowed' area.
Chris B.
camera {location <0,2,-4> look_at 0}
light_source {<-1,50,10>, rgb 0.4}
plane {y,0 pigment {checker}}
sphere {<0,1.5,0>,1
  no_shadow
  pigment {rgb 1}
sphere {<0,1.5,0>,1
  no_image
  no_reflection
  pigment {rgbf <0,0,2,1>}
Date: 24 Oct 2008 15:36:34
Message: <490223c2@news.povray.org>
http://warp.povusers.org/povtips/
Date: 27 Oct 2008 06:00:00
Message: <web.49058fefb038f6fee2381b720@news.povray.org>
Thanks for all. I'm sorry that I was not post a message more datail. Hovewer you
gave me useful answers.
