POV-Ray : Newsgroups : povray.general : difference/ intersect, preserving original texture. Server Time
22 May 2025 20:44:45 EDT (-0400)
  difference/ intersect, preserving original texture. (Message 1 to 9 of 9)
Subject: difference/ intersect, preserving original texture.
Date: 20 Sep 2008 20:40:00
Message: <web.48d596b5affe8f0b34d207310@news.povray.org>
I have an interesting object{}. It itself is a union of multiple,
interestingly-shaped objects of different colors. I want to get a cross section
of it and see the colors of the different layers.
Every way I've tried, however, gives the cross-section the texture of the
cutting object.  Any way to see the colors in my multi-layer cake?
Subject: Re: difference/ intersect, preserving original texture.
Date: 20 Sep 2008 23:23:42
Message: <48d5be3e@news.povray.org>
> section of it and see the colors of the different layers.
cutaway_textures?
Date: 21 Sep 2008 01:39:45
Message: <48d5de21@news.povray.org>
Consider this simple intersection:
intersection {
   sphere { -x,2 texture { Rubber } }
   sphere {  x,2 texture { Chalk } }
One side is Rubber and the other is Chalk, as we expect.  The space
between the surfaces has an interior assigned to it, but it has no
texture associated.  In POV-Ray, the interior of an object does not have
an associated texture that can be seen when an untextured object
intersects into that interior.
If you want to see the different surfaces, then use a clipping object.
It will make the object look hollow, but you'll see the surfaces.
John
Date: 21 Sep 2008 02:39:36
Message: <kG52WvAmwe1IFwXz@econym.demon.co.uk>
>>cross section
>>of the
>intersection {
>have an associated texture that can be seen when an untextured object
When you apply cutaway_textures to an object with overlapping parts, you
get the average of the textures of those parts.
Mike Williams
Gentleman of Leisure
Date: 21 Sep 2008 09:55:22
Message: <48d6524a$1@news.povray.org>
don't you want the cutaway_textures keyword?
Date: 21 Sep 2008 14:15:00
Message: <web.48d68e3f9a86880734d207310@news.povray.org>
It's interesting how this does exactly what I want to **one** layer of the cake,
but not all.   Maybe I shouldda "merged" the layers of the cake instead of
"union"ed them.
Date: 22 Sep 2008 12:13:25
Message: <48d7c425$1@news.povray.org>
gregjohn nous illumina en ce 2008-09-21 14:11 -->
> "union"ed them.
Merge will only make your scene render slower.
You may have areas where to many different components overlap. You may need to
take slices of your various individual components, by intersecting them with
properly sized boxes, and unioning those slices.
Did you know that Al Capone's business card said he was a used furniture dealer.
Date: 22 Sep 2008 13:34:13
Message: <48d7d715$1@news.povray.org>
> need to take slices of your various individual components, by
> intersecting them with properly sized boxes, and unioning those slices.
Alternately/similarly you could texture the whole object using one or
more object patterned textures, so each texture is where you want it to be.
// The Mildly Infamous Blue Herring
#version 3.61;#include"functions.inc"global_settings{assumed_gamma
2.2}isosurface{function{-f_strophoid(x/2-.45,y,z*3,1,1.2,1,1.5)-.05}
contained_by{box{<-2.1,-1,-1/3>,<1.4,1,1/3>}}max_gradient 12inverse
hollow pigment{rgbf 1}interior{media{samples 8 emission<3,80,150>/255
density{crackle metric 1color_map{[0rgb 6][.03rgb 0][1rgb 0]}scale<1,
2,1>warp{turbulence<.5,.75,.5>}scale 1/3}}}translate z*3}
Date: 22 Sep 2008 20:00:00
Message: <web.48d830949a86880734d207310@news.povray.org>
Thanks all for the cutaway_texture suggestion.
I later discovered that I had a dangling texture statement (declared it in a
statement but never applied it to anything) that made me think the whole
cutaway_texture wasn't working properly.  Thanks and sorry.
