POV-Ray : Newsgroups : povray.general : Low Memory Footprint Server Time
19 May 2025 00:58:58 EDT (-0400)
  Low Memory Footprint (Message 1 to 10 of 11)
Subject: Low Memory Footprint
Date: 5 Aug 2008 06:40:00
Message: <web.48982d491b7d5971b5cc26d30@news.povray.org>
Hello,
I have very large triangulated surface mesh and it seems that PovRay
allocate large memory during calculation. Isn't ray tracing is an
embarassingly parallel procedure ? Therefore, I was wondering if it
is possible to have low memory footprint version of PovRay where
performance is not the most important criteria.
I will also appreciate if someone gives some links to a Multi-Core
implementation of PovRay.
Thanks.
With regards.
Chaman Singh Verma
Poona, India
Subject: Re: Low Memory Footprint
Date: 5 Aug 2008 09:38:46
Message: <489857e6@news.povray.org>
  http://povray.org/
Date: 5 Aug 2008 11:43:54
Message: <4898753a$1@news.povray.org>
Well, in my eyes it makes sense to invest some Rupees and buy additional
memory. Memory is not that expensive, and the results pay off.
There was a time I tried with a small amount of memory, but I feel much
better now with the current amount of RAM. I can do all the scenes I want,
the way I want.
I hope it's possible for you to get more RAM.
Date: 5 Aug 2008 17:42:13
Message: <4898c935@news.povray.org>
"ChamanSingh" <nomail@nomail> wrote in message
news:web.48982d491b7d5971b5cc26d30@news.povray.org...
> Hello,
Changing something like that is a huge undertaking. It would require a
massive change to the inner workings of POV.
The official 3.7 beta version of PovRay is multi-threaded. I use it on a
quad core with great effect. It can be downloaded from
http://www.povray.org/beta/
Rarius
Date: 5 Aug 2008 18:33:19
Message: <4898d52f@news.povray.org>
If you don't have too much RAM, but performance isn't important, just let it
swap to disk like crazy :)
Date: 6 Aug 2008 12:10:01
Message: <web.4899cbe58a560d6ed5130d5a0@news.povray.org>
Hello Sven,
I wish things were that simple, but what can I do when my lab data generate
data of more than few TeraBytes and not few GB. Yes, your suggestion is very
great but impractical in many senses.
I just wanted to get an unbiased opinion about this topic, and looking at the
response, I think, we may have to re-implement PovRay type system with very low
memory requirements.
And I must say that Povray is wonderful.
Thanks and With Warm regards
csv
> the way I want.
Date: 6 Aug 2008 12:15:00
Message: <web.4899cce88a560d6ed5130d5a0@news.povray.org>
I think, it is neither professionally nor technically sound answer.
With regards and Warm Wishes/
csv
Date: 6 Aug 2008 15:39:24
Message: <4899fdeb@news.povray.org>
  You won't be able to reduce the memory footprint of a mesh by any
rational means while keeping the entire mesh in memory.
  The only option would be to load only part of the mesh at a time
(ie. only the parts which are needed). Some high-end renderers support
this, but it's a quite complicated thing to implement. One possible
approach is to use the octree POV-Ray already uses for meshes so that
only those nodes which are requested are loaded, and least used nodes
freed. It's not trivial, though.
Date: 6 Aug 2008 16:45:00
Message: <web.489a0c498a560d6e6e78dac40@news.povray.org>
Personally, I've long considered pov to have a low memory footprint anyway.
There is one thing that this post reminded me of, though.  This is applies to
running povray under windows using the GUI - open documents do take up more
memory.  I've dealt with some a fairly large meshes, something like ~8Mb when
saved as an include by itself.  If you have the document open in one of the
tabs, it does take up that extra bit of RAM.  In this case, when we are talking
about terabytes, an analogous concept could be used by splitting the large
mesh(es) into smaller chunks, then loading and rendering only the visible
portions of the mesh, or even splitting the image into chunks and rendering
each chunk separately.
  Personally, I am kind of curious as to what type of data this is.  If a mesh
that dense is completely within the camera view, the resolution required to
tell the difference between that mesh and another with 1/100th of the triangles
must be very high.  If not all of the mesh is visible, then it can be split into
pieces.
-Reactor
Date: 6 Aug 2008 19:13:40
Message: <489a3024@news.povray.org>
>> it swap to disk like crazy :)
Any solution built into POV-Ray would behave a bit similar to the operating
system's virtual memory anyway. Like Warp said: "One possible
freed." Except for the octree (which surely is an advantage), that sounds
like the "swap to disk the least recently used piece of memory" operation
the OS does whenever it feels low on physical RAM.
