POV-Ray : Newsgroups : povray.general : Turbulence Server Time
6 Mar 2026 04:20:57 EST (-0500)
  Turbulence (Message 1 to 5 of 5)
Subject: Turbulence
Date: 13 Jul 2008 23:35:00
Message: <web.487ac91721894969302c26d00@news.povray.org>
The current turbulence warp I'm using just kind of swirls the texture around.
warp
 turbulence 1/8  //.125
 lambda  3  //3
I am wondering, how do make it so that there are also speckles--i.e., almost a
dithered or half-tone pattern?
-Mike
Subject: Re: Turbulence
Date: 13 Jul 2008 23:48:04
Message: <487AE95D.2040807@joplin.com>
> warp
>  lambda  3  //3
> -Mike
Depending on the pigment your using you can try turbulence grater than one.
I'd have turbulence of 10 with a gradient pigment map.
Date: 14 Jul 2008 01:05:01
Message: <web.487add66be836f17302c26d00@news.povray.org>
Thanks! I'll have to experiment a bit to see what results are possible.
On a further note, has anyone created a (fractal?) pattern that can produce the
rippled effect found in this satellite view of the Himalayas?
http://www.everest-2002.de/bilder/STS058-101-12a.jpg
Thanks again!
-Mike
Date: 14 Jul 2008 07:12:50
Message: <487b34b2@news.povray.org>
web.487add66be836f17302c26d00@news.povray.org...
>> one.
> produce the
> Thanks again!
> -Mike
My best guess should be f_ridged_mf() function available in the
functions.inc standard include file though erosion is hard to simulate.
For speckles in transitions, did you play with lambda and omega?
BTW I'm following your excellent work and I jump on the opportunity to say
it is a very good job :-)
Marc
Date: 15 Jul 2008 07:05:01
Message: <web.487c8443be836f1760cc59ad0@news.povray.org>
Thanks. I will try that too.
> Marc
Thank you! Once I get the orbit code working and add a nice atmosphere I will
release it.
-Mike
