POV-Ray : Newsgroups : povray.general : Sqrt() and rotate goofiness? Server Time
23 May 2025 03:14:14 EDT (-0400)
  Sqrt() and rotate goofiness? (Message 1 to 6 of 6)
Subject: Sqrt() and rotate goofiness?
Date: 9 Jul 2008 13:45:00
Message: <web.4874f7aec23a6d9c59235590@news.povray.org>
I'm trying to understand how I'm screwing this up.  I'm running POV v 3.6 on
WinXP, and I'm confused as to why it crashes when using the code below...
I've marked 3 lines to play with.  If I uncomment any combination of these lines
things work fine EXCEPT if Line #3 is uncommented all alone.  Then, POV throws
an unhandled exception and needs to be reloaded.
Lines #1 and #2 are the essentially the same math as #3, except I've split the
position and the rotation of the sphere up.  Why does it choke on the
combination of the two, but not on the single operations?
#version 3.6;
camera {location 10*y  look_at 0}
light_source {<-30, 30, -30> color rgb <1, 1, 1> }
#declare ii = 0;
#declare X0 = 0;
#declare X1 = 1;
#while (ii <= 360)
   #declare ii = ii + 1;
   #declare X1 = X1 + X0;
   #declare X0 = X1 - X0;
   //sphere{<sqrt(X0),0,0>, 0.1 pigment{rgb 1}            } // Line #1
   //sphere{<       1,0,0>, 0.1 pigment{rgb 1} rotate ii*y} // Line #2
   //sphere{<sqrt(X0),0,0>, 0.1 pigment{rgb 1} rotate ii*y} // Line #3
Subject: Re: Sqrt() and rotate goofiness?
Date: 9 Jul 2008 13:55:29
Message: <4874fb90@news.povray.org>
  It doesn't crash here. However, I wonder if the problem might be in
that X0 is getting *huge* values.
Date: 9 Jul 2008 15:50:36
Message: <Ryt$ejCHaRdIFwil@econym.demon.co.uk>
It crashes for me with 3.6 under Windows XP.
I noticed that:
   it doesn't crash if the radius of the spheres is larger.
   the larger the value of the radius, the larger X0 can be
   it doesn't crash if there's a single sphere equal to the last one
   it doesn't crash if automatic bounding is switched off
     which would explain the previous point, because automatic bounding
     is normally switched off for less than three objects
Mike Williams
Gentleman of Leisure
Date: 9 Jul 2008 16:15:00
Message: <web.48751b813b377786c59235590@news.povray.org>
Heh, I agree that the values are silly.  But I don't understand why those exact
same values are accepted for both Lines #1 and #2, but not #3.  Where exactly
are the large values screwing things up?
Date: 10 Jul 2008 01:08:27
Message: <r6KxsaBbeZdIFwkL@econym.demon.co.uk>
It's clearly in the processing of the automatic bounding slabs.
Perhaps rounding errors are causing some of the bounding slabs to have
negative volume. If the rotation calculations are accurate to 1 part in
10^26 then that error could be larger than 0.1, the radius of the
sphere. I tried to check out this theory by looking at max_extents and
min_extents, but they seem to only return 6 digit accuracy, so the
interesting spheres all appear have volume zero.
Mike Williams
Date: 10 Jul 2008 09:25:00
Message: <web.4876064a3b377786c59235590@news.povray.org>
You're right, of course.  I see that if I turn off automatic bounding altogether
(-UB) then I cannot produce an error, regardless of what I choose for a radius.
I can do this, though:
#declare Y0 = vrotate(<sqrt(X0),0,0>, ii*y);
sphere{Y0, 1E-0 pigment{rgb 1}} // Line #3
Rather than:
sphere{<sqrt(X0),0,0>, 1E-0 pigment{rgb 1} rotate ii*y} // Line #3
The former doesn't crash (while the latter does).  I suppose I assumed that
vrotate() would be the same math as the rotate keyword.  Does that mean
calculating sqrt() + rotate 'on-the-fly' yields larger rounding errors than
using the vrotate function?  The bounding box calculations should be the same
in either event, shouldn't they?  (Clearly, they're not.)
So... it seems POV doesn't check for negative bounding volumes.  I've never
looked at the source code, but maybe it's an easy fix.  :)
Thanks for your patience in helping me understand.
- How
