Hi!
Are there some instructions somewhere on converting halo blocks to
interior/media? I'm working with some legacy code at the moment and am not sure
how to go about doing the conversion.
Thanks!
-Mike
"SharkD" <nomail@nomail> wrote:
> Hi!
> Thanks!
> -Mike
<474f3e5b$1@news.povray.org>
> "Nobody, and no algorithm or trick can do that. Halos and media are
> really different beasts. The best you can do is learn to use media,
> then try to re-create the effect. That's a classic problem, and this
> was always the only answer, sorry.
> Fabien."
> > Hi!
> > Thanks!
> > -Mike
> > Fabien."
Thanks for the response. It's too bad though ;-)
One of the major problems is that media density components do not
support the filter/transmit channels. This makes it impossible to
simulate certain halo effects with media. (And no, I don't think this
is a good thing, and I think media should be enhanced in this respect.)
For example having a density like this was possible with halos:
[0 rgb 1 transmit 0]
[1 rgb <1, 0, 0> transmit 1]
With current media densities it's basically impossible to get the
same effect.
That said, can anyone help me with converting the following code? Thanks!
halo
cubic
max_value 3 spherical_mapping glowing
colour_map {[0 color rgbt <1,0,0,1>][1 color rgbt <1,1,0,0>]}
turbulence 1.5 samples 30
halo
cubic
turbulence 1.05 samples 30 scale .5
rotate y*45 translate y*1
-Mike
As I said in my post, it's not possible.
> halo
> cubic
> halo
> cubic
> -Mike
As Warp pointed out in his example, the transmit component (rgb*t*) isn't
possible, media ignores it. Maybe you could try using MegaPov's glow feature?
What are you trying to achieve? Can you post a sample image?
-Rob
"There is no spoon."
> -Rob
It's supposed to look like a flame shooting out of a rocket, I think. I'm not
sure, I haven't been able to render it myself yet.
-Mike
> -Rob
Has a free version of MegaPov been released yet? I thought it was still in
development.
-Mike
> development.
> -Mike
MegaPov has always been free - the latest "official" unofficial release was just
over a year ago. It's just like POV-Ray with lots of additional features built
in:
http://megapov.inetart.net/
-Rob
