POV-Ray : Newsgroups : povray.general : No file was written... Server Time
25 Aug 2025 03:35:53 EDT (-0400)
  No file was written... (Message 1 to 6 of 6)
Subject: No file was written...
Date: 8 Jul 2008 15:30:00
Message: <web.4873bff033fbed2dc0721a1d0@news.povray.org>
I get a warning "A render has completed but file output was turned off. No file
was written" when I run this ini-file:
; ini-file starts here *******************************
Input_File_Name = 0018a009.pov
Output_To_File = on
Height = 10000
Width = 10000
Start_Column = 1
End_Column = 100
Start_Row = 1
End_Row = 100
; ini-file ends here ********************************
A file is created when I comment out the Output_File_Name statement, though.
What am I doing wrong?
Subject: Re: No file was written...
Date: 9 Jul 2008 01:35:01
Message: <web.48744ce092a7e775c0721a1d0@news.povray.org>
> Output_To_File = on
> Height = 10000
> Width = 10000
> Start_Column = 1
> End_Column = 100
> Start_Row = 1
> End_Row = 100
Fixed by using +o instead of Output_File_Name. Is this a bug? I presume
"Output_File_Name" is spelled correctly, otherwise POV-Ray would ignore it and
write to the default output file, as if the statement were commented out.
Date: 9 Jul 2008 04:17:48
Message: <4874742c$1@news.povray.org>
>> Output_To_File = on
>> Height = 10000
>> Width = 10000
>> Start_Column = 1
>> End_Column = 100
>> Start_Row = 1
>> End_Row = 100
RTFM about the difference between an option with "+" and an INI option.
	Thorsten
Date: 9 Jul 2008 05:15:00
Message: <web.487480e492a7e775c0721a1d0@news.povray.org>
From the FM:
"+Ofile  Same as Output_File_Name=file".
What else do I need to know?
Date: 9 Jul 2008 15:00:00
Message: <web.487509ea92a7e77586ff1d480@news.povray.org>
> > Output_To_File = on
> > Height = 10000
> > Width = 10000
> > Start_Column = 1
> > End_Column = 100
> > Start_Row = 1
> > End_Row = 100
Steven, this may be just a dialog box bug - I tried it and got the same message,
but the file was written to disk anyway. I just checked the "Don't tell me
again" box. All fixed. I used the following INI file on the Basic Scene:
Input_File_Name = basicScene.pov
Height = 1000
Width = 1000
Start_Column = 1
End_Column = 100
Start_Row = 1
End_Row = 100
-Rob
Date: 9 Jul 2008 17:19:39
Message: <48752b6b$1@news.povray.org>
> Output_To_File = on
> Height = 10000
> Width = 10000
> Start_Column = 1
> End_Column = 100
> Start_Row = 1
> End_Row = 100
Thanks for the report, I will look into it and if there's a bug I will fix it.
regards,
-- Chris
