POV-Ray : Newsgroups : povray.general : Light with negative refractive index Server Time
25 Aug 2025 10:41:46 EDT (-0400)
  Light with negative refractive index (Message 1 to 4 of 4)
Subject: Light with negative refractive index
Date: 28 Jun 2008 04:40:01
Message: <web.4865f7c585dff5ef25acb1ab0@news.povray.org>
Dear Sir/Madam
This is R.Varalakshmi and i am doing my year 3 Electrical Engineering at the
National University of Singapore. I am currently working on a research project
under my professor on negative refractive index materials. I have a certain
doubt and don't know anybody else to approach for the same, when by chance i
saw your thread on the net with regard to POV. Sorry for the random mailing but
your help could mean a lot to me.
Could you please tell me if there is a way to create pictures using POV Ray
tracing for light with a negative refractive index. And though it is still not
existent in the real world, my job is to produce the effects which can be seen
by the negative refractive index materials in pictures. I want to know whether
this is possible using POV Raytrcaing and if yes please tell me on how to
implement the idea.
I would be very grateful for any sort of help or advice from you at the
earliest.
Thanks and Regards
R.Varalakshmi
Subject: Re: Light with negative refractive index
Date: 28 Jun 2008 05:34:42
Message: <486605b2@news.povray.org>
"Varala" <var### [at] gmailcom> wrote in message
news:web.4865f7c585dff5ef25acb1ab0@news.povray.org...
> Dear Sir/Madam
> the
> project
> certain
> i
> mailing but
> Ray
> not
> seen
> whether
> implement the idea.
> earliest.
> Thanks and Regards
> R.Varalakshmi
The IOR setting in POV-Ray does accept negative values. I couldn't tell you
whether it is theoretically optically correct, but it does render something
different from the equivalent positive value.
The following complete POV-Ray scene file renders a transparent sphere and
box on a checkered plane. The IOR is controlled by the clock so that it
passes from 2 to -2 when rendered with animation command-line options such
as +kfi0 +kff21 (or ini file settings of: Initial_Frame=0 Final_Frame=21).
Chris B.
// Animation options: +kfi0 +kff21
camera {location <0,3,-5> look_at <-1,1,0>}
light_source {   <100,100 ,-100>, rgb 1}
sphere {<0,0,0>,2
  pigment {rgbt 1}
  interior {ior 2-4*clock}
  // or, if you don't want to animate, use:
  // interior {ior -1.1}
box {<-4,0,0>,<-2,2,2>
  pigment {rgbt 1}
// A Checkered Plane
plane {y,-3 pigment {checker}}
// A Sky
sky_sphere {
    gradient y
    color_map {
      [ 0.5  color <0.7,0.7,1> ]
      [ 1.0  color <0.2,0.2,1> ]
    scale 0.2
    translate -1
Date: 28 Jun 2008 07:08:13
Message: <48661b9d@news.povray.org>
>> Dear Sir/Madam
>> the
>> project
>> certain
>> i
>> mailing but
>> Ray
>> not
>> seen
>> whether
>> implement the idea.
>> earliest.
>> Thanks and Regards
>> R.Varalakshmi
> Regards,
> Chris B.
> sphere {<0,0,0>,2
>   pigment {rgbt 1}
>   pigment {rgbt 1}
> // A Sky
> sky_sphere {
>   pigment {
>     gradient y
>     color_map {
>     scale 0.2
>     translate -1
May I point you to a paper published by Dolling, Wegener, Linden and
Hormann on 6 March 2006.
http://www.opticsexpress.org/abstract.cfm?id=88325&CFID=29931998&CFTOKEN=78387185
I believe this may help answer your question
John
I will be brief but not nearly so brief as Salvador Dali, who gave the
world's shortest speech. He said, "I will be so brief I am already
finished," then he sat down.
Date: 30 Jun 2008 08:46:02
Message: <4868d58a$1@news.povray.org>
Varala wrote:
> Dear Sir/Madam
> implement the idea.
> earliest.
Christoph Hormann has some demonstrations of rendering metamaterials
with POV-Ray at http://www.imagico.de/pov/metamaterials.html
-The Mildly Infamous Blue Herring
