POV-Ray : Newsgroups : povray.general : Rock faces Server Time
6 Mar 2026 10:13:50 EST (-0500)
  Rock faces (Message 1 to 8 of 8)
Subject: Rock faces
Date: 19 May 2008 19:55:00
Message: <web.4832125f33712916eb86c0c0@news.povray.org>
I'm trying to do a sort of recreation of the Zipaquira Salt Cathedral, but I'm
having trouble making the rock faces look like rocks. I need something that
will produce a hewn stone shape, something smooth but irregular. With the
shapes I used, I can't seem to attach said properties.
Would heightfields work?
Anything else?
Subject: Re: Rock faces
Date: 20 May 2008 21:40:01
Message: <web.48337d049c3d34efa05240db0@news.povray.org>
> Anything else?
I would suggest a bozo pigment of varying greys scaled down really small.  If
this doesn't work quite well, then I would suggest trying to add a bozo normal
that is too scalled small.
try this:
texture
       pigment{ bozo color_map{[0 rgb 0.6][0.3 rgb 0.4][0.7 rgb 0.7][1 rgb 0.6]}
scale 0.01}
       normal{bozo 0.1 scale 0.01}
Date: 20 May 2008 22:25:34
Message: <4833881e@news.povray.org>
> Anything else?
Would Bill Pragnells Weathered Objects macros help?
http://tinyurl.com/3r2dnk
Date: 28 May 2008 12:35:01
Message: <web.483d88ec9c3d34efbc52d3e20@news.povray.org>
> > Anything else?
> try this:
> texture
> scale 0.01}
I didn't know you could use textures as normals.
Will changing the normal actually change the object, or will it just make it
look different (like when you use bumps?)
Anywhoo, I'll try this out and report back.
You know you've been doing POV-Ray too long if you wonder how many layers God
used to pigment the universe.
Date: 28 May 2008 12:40:00
Message: <web.483d8a089c3d34efbc52d3e20@news.povray.org>
> > Anything else?
Well, the stone isn't weathered, its tooled, but this looks helpful for later,
thanks!
Date: 28 May 2008 15:01:24
Message: <483dac04$1@news.povray.org>
Aarqon nous illumina en ce 2008-05-28 12:31 -->
>>> Anything else?
>> try this:
>> texture
>> scale 0.01}
Normals never affect the actual shape of the object, just the aspect of it's
surface.
If you want to affect the actual shape of the object, you need to use an
isosurface or a mesh and use the pigment to push the surface in or out. If you
use an isosurface, you add or substract the pigment to the function(s) that is
used to deffine your object.
Seventh Day Adventism: No shit shall happen on Saturday.
Date: 28 May 2008 19:50:23
Message: <483defbf@news.povray.org>
>>>Anything else?
> thanks!
You might find a crackle pattern form <1,0,0> gives a reasonable
simulation of a punch chisel
Date: 28 May 2008 23:42:54
Message: <483e263e$1@news.povray.org>
Aarqon napsal(a):
Actually, it's a very dense media
You know you've been raytracing too long when...
you refresh your inbox after sending a message
		-Johnny D
Johnny D
