I have a layered texture. Pigment is transparent in some places so lower layers
show through. I can't map the texture because then I can't layer them. If I
apply an irid finish to each layer, they add up and wash out the texture. If I
apply irid at then end, outside a texture block, only the top-most texture picks
it up. If I apply it inside a texture block, it doesn't work with the layered
normals. Is there a way to simply apply an iridescent finish to the whole
texture?
- Ricky
