POV-Ray : Newsgroups : povray.general : Using povray at the command line in windows Server Time
6 Mar 2026 10:12:21 EST (-0500)
  Using povray at the command line in windows (Message 1 to 10 of 12)
Subject: Using povray at the command line in windows
Date: 3 May 2008 19:00:00
Message: <web.481cecaf909686ded1dda480@news.povray.org>
All,
I'd like to execute povray from the command line, but that does not appear to be
an option with the current windows version.
What I want to do is produce a sequence of images, each of which depends upon
two parameters, phi and theta. The values of phi and theta are generated in
Matlab and saved to a text file.
A former student of mine wrote a script on a unix box to accomplish the task:
cat defs.ini | sed s / var1 /$THETA/ | sed s / var2 /$PHI/>newdefs.ini ;
povray -W640 -H480 +Oanim-$TIME.png anim.pov ;
done ;
But I don't seem to have access to the "povray" command in a DOS box to mimic
this approach.
Is there a suggested alternative?
Thanks.
David.
Subject: Re: Using povray at the command line in windows
Date: 3 May 2008 19:27:22
Message: <481CF504.2080409@hotmail.com>
darnold wrote:
> All,
> done ;
> this approach.
You can call povray directly from matlab. The executable is called
pvengine.exe .
The key lines in my povray.m files are:
function povray(povfile,varargin)
[parsing name-value pairs in varargin]
POVpath='c:\program files\pov-ray for windows v3.6';
POVpath='c:\progra~1\pov-ra~1.6'; %DOS version without spaces
s=sprintf('!"%s\\bin\\pvengine.exe" +I%s',POVpath,povfile);
and then after possibly adding /EXIT (and other parameters) to the
string I call
eval(s);
I hope that helps. I could also give you my povray.m but it depends on
some other script to parse the name-value pairs. And I don't want to
write documentation for that (it is fully documented but not in the
matlab script itself)
Date: 4 May 2008 11:08:40
Message: <481dd178$1@news.povray.org>
andrel nous illumina en ce 2008/05/03 19:28 -->
> darnold wrote:
>> All,
>> appear to be
>> depends upon
>> generated in
>> the task:
>> f o r a in ‘ cat odeoutput.txt | sed ”s/ /_/g” ‘ ; do
>> TIME=‘echo $a | cut -d'_’-f1 ‘ ;
>> THETA=‘echo $a | cut -d ’_’ -f2 ‘ ;
>> PHI=‘echo $a | cut -d ’_’ -f3 ‘ ;
>> done ;
>> to mimic
>> this approach.
> pvengine.exe .
> string I call
> eval(s);
Don't use "/exit" if you want to render more than one image. If you use that,
you'll force POV-Ray to get started for each image, then unloaded, and you'll
get the splash every time.
History, in general, only informs us of what bad government is.
Thomas Jefferson
Date: 4 May 2008 12:25:46
Message: <481DE3B4.40209@hotmail.com>
>> darnold wrote:
>>> All,
>>> appear to be
>>> depends upon
>>> generated in
>>> the task:
>>> done ;
>>> to mimic
>>> this approach.
>> pvengine.exe .
>> string I call
>> eval(s);
> that, you'll force POV-Ray to get started for each image, then unloaded,
> and you'll get the splash every time.
True but the script continues only after pov is closed. If you don't use
/exit you have to manually close pov to continue in matlab. That is
generally not what you want. Unless there is a trick to run the system
command in another thread.
If you don't like the splash you can always use megapov.
In this case I think I would write implement it as an animation and
write all time theta and phi values to a file at once or perhaps one
include file for every framenr and use string concatenation to get the
right parameter file.
Date: 4 May 2008 12:38:44
Message: <481DE6BF.6070907@hotmail.com>
andrel wrote:
> Unless there is a trick to run the system command in another thread.
hmm, yes there is. Just add a '&' at the end. I might have guessed :(
Date: 5 May 2008 01:58:04
Message: <481ea1ec$1@news.povray.org>
Does that work in DOS/Windows?
William Tracy
Don't code to live; live to code!
Date: 5 May 2008 12:07:30
Message: <481f30c2$1@news.povray.org>
It depends on whether "DOS/Windows" means "DOS" or "Windows." The two
haven't been related in close to a decade.
It works under any version of Windows you're likely to be running these
days.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Date: 5 May 2008 19:55:45
Message: <481f9e81@news.povray.org>
> days.
Not really.
& in a Windows prompt has a different meaning. a & b is like Unix's "a; b;"
(runs both commands, one after the other) and a && b is the same as in Unix
(runs both commands, but if a fails then b isn't run).
I have a port of Unix's "env" command that, due to a *bug*, returns
immediately and leaves the program running. I abuse that to run stuff in
the background on Windows. Either that or I start cygwin :)
Date: 5 May 2008 20:25:50
Message: <481fa58e@news.povray.org>
Duh, DOS wasn't actually multitasking, so it wouldn't work there.
Now that makes me curious what Windows would do if you entered a command
with nothing after the ampersand. I may need to track down a Windows
system and play with it. :-)
I've reached the point where I can't be productive in Windows without
Cygwin. :-P
William Tracy
    It occurred to him that now he was going to be not only the first
man on Mars, but the first detective. He grinned at the thought, and the
last action of the omegendorph set his nerves aglow.
     -- Kim Stanley Robinson, _Red Mars_
Date: 5 May 2008 20:29:00
Message: <481fa64c$1@news.povray.org>
>> days.
> Not really.
Whoops. Sorry. Don't know where my brain was. Too much Linux or Tcl
lately. :-)
Put "start" on the front to get it running in the background.
